CAn I get a firmware update to add Hulu to my BD640
Can I add Hulu to my TV without another streaming device
If you have smart TV you may check your app store if there is app for hulu otherwise you will need some kind streaming device with hulu app installed
Dec 03, 2017 | Televison & Video
Why is device activation code not working for hulu plus?
Activate hulu com Activate on Roku com link How to Activate Hulu using hulu com activate on Roku Install Hulu App
Get steps to step easy instruction to install and activate hulu com on Roku
1. If you follow all the activation steps then you can easily watch Hulu plus on your TV using the Roku streaming player. This is all about how to watch Hulu plus using the mobile device.
2. This is recommended to use the Roku streaming player as it is very easy to setup and activate as compare to other streaming devices. It's very easy to connect and setup Roku player with your TV.
3. For connecting media player with TV, you only need an HDMI cable. With the help of HDMI cable, you can easily do this. In case your TV does not support the HDMI cable then you can use the A/V cable for the connection.
4. So, for more information, you can go to roku.com/link. Roku com link help will also help you in activating your Roku streaming device.
Jan 14, 2016 | Vizio L32 32 in. LCD HDTV
How do i get hulu on my smart tv?
Hi Sue,
Smart TVs come with a selection of built in applications such as Netflix, Pandora, Facebook, Hulu, etc. In order to view Huku programming you'll need to have your TV connected to the internet either via WiFi or a physical cable plugged into the network jack (if so equipped) on your TV. Once you've successfully set that up, you need to check the TV to determine *IF* they have provided Hulu connectivity inside the TV.
If Hulu does not appear as an application, you may not be able to view Hulu programs without additional work / expense or both. You should check to see if your TV accepts "updates" or "firmware updates" and if so, follow the instructions on how to obtain and install them. Most will simply download and install automatically via WiFi or network cable - yours may or may not. Check the manual if unsure. If it does accept updates - it may include Hulu connectivity - and you can skip ahead.
If it does not - your TV manufacturer may not have reached an agreement with Hulu to offer their programming - yet. Check back form time to time to see if an update addresses this for you. If you don't feel like waiting for an update that *may* provide Hulu access, you can purchase an external device such as Roku or Chromecast (there are probably others, too) to provide access right away. Check all available devices to see which services / apps they provide - not all devices support all apps. Once you have a device capable and successfully installed or otherwise have an option for Hulu on your TV screen you can move on.
Next, activate a new Hulu subscription on the TV by following the instructions on the screen. Some hardware may require that you complete a registration before you can do that - so follow the instructions of the hardware first if needed. If you already have an account, you may use your existing Hulu login credentials to log in as opposed to creating an new / additional account - unless you want to take advantage of some of the free 30 day trials offered by many of the applications for "new" users.
Hopefully, you'll be watching in no time! Good luck!
Dec 10, 2014 | Televison & Video
I want to update my netflix and hulu apps to the newer versions on my vizio E3D420VX TV
Updates will come from netfix and hulu. look for update option when on those sites.
Apr 01, 2014 | Vizio E3D420VX 42-inch 1080p 120Hz 5ms 3D...
LG BD640 chassis, HDMI and RCA jacks all have alternating current that shocked me. Measuring between the outside ring on the cables to wall jack = small side has 33V AC and the wide has 92V AC. Where is...
First thing to check is the electrical outlet that they plug into. You can get an outlet tester at any hardware store. You might have a floating ground in the outlet. The small spade on the outlet should be the hot one. You can ground it as you describe but I am suprised that the devices were not damaged by this voltage.
Feb 26, 2014 | LG BD370 BLU RAY PLAYER
Philips tv troubleshooting
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Trouble shooting chart to Philips brand TVs are given.
Jan 08, 2014 | Televison & Video
Imac G4 0s 10,4.11 need a flash to watch hulu free tv
You can't watch Hulu on a PowerPC iMac G4. You need an Intel processor based Mac to watch Hulu and Netflix.
Dec 19, 2012 | Apple A1106 Powerbook G4 15", 1.67 Ghz,...
Hulu plus problems with my Sharp TV
If you are trying to play Hulu from a cell or PC, the HDMI is automatically disabled. As far as I can see, Hulu is not available as a Sharp Aquos app either even with the latest firmware. I have to use my older Vizio smart TV. Go figure.
Nov 23, 2012 | Sharp Televison & Video
Televison & Video Logo
Top Televison & Video Experts
