Question about Dishwashers
I have a Brada countertop dishwasher the door of the dishwasher does not lock something wrong with the latch
Me too- i manually close it but from time to time the latch will not come on done
Posted on Mar 28, 2010
Should the steam vent on top of Kitchenaid dishwasher be visible when door is latched or should it be jnder countertop completely?
unless you have a granite countertop I would say it needs to be seen wood getting steamed will rot out rapidly
Jan 16, 2016 | KitchenAid Dishwashers
Bosch sms63mo8au 12 door latch
Could be the latch that's attached to the top of the outer shell frame has become loose and is out of alignment, so its not able to close properly. Pull the unit out from under the countertop and have a look at whats happening with the latches when you try to close and lock the door. Adjust as need.
Aug 07, 2014 | Bosch Dishwashers
Can't open door
get a coat hanger or flexible wire and try to run it under latch from the top. This may be difficult depending on how your countertop is. Once it's under the latch from one side to the other, pull up on both sides of wire to raise the latching mechanism. Open door.
Oct 24, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Mar 13, 2010 | GE 24 in. Profile PDW7800 Built-in...
Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Aug 18, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Apr 17, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Brada ef2401 door won't close
We actually had the same problem with our Brada dishwasher. There is a plastic clip inside the door that latches on to the dishwasher to keep the door closed. In our case this clip had flipped inside the door (periodically continues to happen to this day). To resolve we took the door apart - carefully - and flipped the clip back into proper position. You can only do this if the dishwasher is not under warranty as once you take it apart you will likely void the warranty on it.
Aug 12, 2008 | Dishwashers
Door handle broke
.with a little luck you can try jiggling it for a while youmight get it ot pop open, if not youll needs to remove it from under counter. its held under countertop by 2 phillips screws (dropping the adjustmendt legs under unit will give you additional clearance to acess the screw head. after sliding d/w foward only 3 or three inches you gain acesss to the strike plate thats locking your latch. youll need to replace door latch and/or handle.
Feb 24, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Dec 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
335 people viewed this question
Top Dishwashers Experts
