Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater R155A
Well, Got it fixed, your not gonna believe this!........
The pitch of the fan blade was off by a 1/8 of an inch, starts and runs great,
I guess you could call me Moses too!
Thanks for all the help and support!
Respectfully
Hojo58
  • hojo58 Jan 25, 2009
    original... I never touched it
  • 232 Answers
Congratulations. Was it the original fan, or had it been changed out?
Posted on Jan 25, 2009
I have a reddy heater 40,000 btus and it works with the top off but when I put the top piece back on the fan hits it? what do I do
Either the fan blade is loose or the mount is loose, or the outside of the heater has been damaged/dented and hitting the blade.
Feb 28, 2015 | Reddy Heater-30-55,000 BTU Variable
Either the fan blade is loose or the mount is loose, or the outside of the heater has been damaged/dented and hitting the blade. Leaving the top piece off is only an option if there are no pets or children around.
My pro 110 reddy heater worked last year this year it buzzed until reset popped also the fan motor does not turn
Many times a fan or heater setting over the extended unused period become blocked by mud daubers. I'd start by checking for one in the fan blade.
Dec 04, 2014 | Heating & Cooling
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
R155A Reddy Heater Help!
This is going to be a tough one. You have been thorough, done it right, and it damn sure ought to fire off every time!
There is something that is causing you a problem and don't think that because you put in new parts that you didn't get a bad part. It happens. Not often, but it does happen. I have rec'd nozzles from the factory that had the orifice installed sideways, so, I know it happens.
If the ignitor glows- (it only stays on for 5 seconds, then quits)
If the fuel fogs (not sprays)
If the fuel hits the glowing ignitor
Then it should fire off-- every time.
Now, if the photocell doesn't like what it sees, then the photocell will shut the heater down within 5 seconds, but it at least should have ignited. Right? Unless the photocell or the board are bad. Maybe.
Lift the top, and watch. What's happening. Are you having a fuel problem or an electronics problem? For instance- is the ignitor glowing every time at start up or only sometimes.
Let me know what you find.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 70 (Kerosene) won't start
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Jan 05, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater r110
Take reading on the air pump. Is sounds like the pressure is low, therefore not sucking fuel. It's a place to start, anyway.
How to check the pump pressure
Dec 05, 2008 | Reddy R60A Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
91 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
