Question about Sova DSV32P112 32 in. LCD Television
I need a replacement channel changer
Please direct me to a replacement
  • Anonymous Jan 30, 2009
    i can not trun the cable of it.
    Novelist:
  • 101 Answers
If you want a replacement for the TV itself you have two ways to go about it. One is contact the manufacturer and get one from them. The other is you can get what I have that I swear by. I have a logitech universal remote that works everything. This one cost me about 90 dollars but it works everything with one touch button. I saw watch TV and it turns on the TV my directv and my surround sound all at the same time. If I press watch DVD it will change the input on the TV turn on the DVD player and switch the surround sound. You program it online with a USB cable that comes with it. It will work basically anything except a Playstation 3 as they are blue tooth. Let me know what the outcome is and if this was helpful to you. Good luck and have a great weekend.
Posted on Jan 24, 2009
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
Bus control
You need to provide Clock n Data signal to activate Bus Audio Source. Actually this Bus Control Socket is to attach Multi Disc Player of Sony. Here is 2 pictures attached of bus related area for info. I am sorry, its difficult to hear MP3 sound at Bus Audio input in this model. Have nice day.
Jul 16, 2008 | Sony CDX-CA600X CD Player
My LG LHT874 system is not reading any dvds. Can you please advise on the best course of action. The system is only 3 years old. Should I attempt to utilize a DVD cleaning kit? If not, is it worth...
You can contact directly by email. Please check online click "About us" avsystemparts.
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Jan 07, 2011 | LG LHT874 Theater System
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
Only works on right channel, radio ok on both
That type of changer has an RCA cord from head unit to changer, try to check if one is not connected,if both are connected, try to interchange the red and white RCA plugs ( the left & right signals) if the left channel will work, you must repair or replace the cord.
Feb 03, 2010 | Sony CDX-T69 6-Disc CD Changer
RCA Colortrak 2000 remote control will do everything except change channels.  I have Insight coax cable, just having disconnected from Direct TV satellite connection--only because new apartment does not...
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Dec 13, 2008 | Akai LCT2701AD Television
I need to know what fm station to put the radio on
It should have an fm transmitter that has 3 options (more or less) beginning with 88.5, 88.7, 88.9, etc. pick any one of the three and turn on the cd changer. If it works properly then you should be able to hear your music. The one you pick should correspond with the channel frequency of the radio or head unit.
Oct 21, 2007 | Jensen XCH6RF 6-Disc CD Changer
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Record one channel while watchign another
Ouirkygirl, a TV\VCR combo can only watch TV on a channel & record THAT channel. If the monitor is connected directly to the VCR then u should be able to RECORD what u see. Do you have a separate channel changer [buttons that say up\down channel ?] on the face of the VCR portion? If so, then u should be able to change the channel ON the VCR, record that channel, then change the channel ON the TV, .... I don't think so,.........any thing is possable
please explain your words :: "but when I record something it jumps to tha channel evern if I am watching something else at the time."
Aug 24, 2007 | Sharp 13VT-K100 13 in. Combo
Sova DSV32P112 32 in. LCD Television Logo
133 people viewed this question
Top Sova Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
loony2ns
Level 1 Expert
Are you a Sova Televison and Video Expert? Answer questions, earn points and help others
