Question about HP PHOTOSMART PLUS B209A All-In-One Printer
Paper jam HP photosmart plus B209A - HP PHOTOSMART PLUS B209A All-In-One Printer
5 Suggested Answers
SOURCE: paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Posted on Mar 24, 2009
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Posted on Apr 20, 2009
  • 13433 Answers
SOURCE: HP Photosmart C6280 paper jam--won't print (of
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 11, 2009
puertobori
  • 7733 Answers
SOURCE: HP Photosmart Plus B209a has
Try this link An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English).
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Jul 07, 2011
How do i change the ssid on my photosmart plus b209a-m printer
Step 1: Click on Windows icon (bottom left hand screen)
Step 2: Select Devices and Printers
Step 3: Right Click on "HP Photosmart Printer Plus B209a-m"
Step 4: Select "Printing Preferences"
Step 5: Click on Tab "Features"
Step 6: Select "Printer Services" in the bottom right hand corner
Step 7: Click on tab "Network Settings"
What you click on there depends on what's wrong with your setup, I think. Mine had a "Configure Wireless" option where I was stepped through the process.
Good Luck!
Jul 10, 2012 | HP Photosmart Plus B209A All-In-One Color...
Wrong language accident put printer in "Korean" of
You need uninstall first software driver of HP PHOTOSMART PLUS AIO PRINTER B209A PHOTOSMART PLUS AIO PRINTER B209A All-In-One. and Then reboot your PC. then install again software driver for that printer select English language version.
Oct 16, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
I have a photosmart B209a printer that produces small lines on my pictures. I replaced the ink thinking it might be that easy, but no dice. Any ideas for cause and cure
I had a similar problem initially and the fault was with the photographic paper. The lines were very regular, just over 1cm apart. Once I switched to HP Advanced paper it cured it.
Jan 14, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
Photosmart Plus B 209. Getting paper jam message over and over but there is no paper jam. i am just doing the install and the very first page said jam repeatedly.
Hi Please refer to the link given below to resolve the issue that you are facing with your printer and before performing these steps please make sure that you printer is connected directly to the wall jack and not to the surge protector
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01768839&cc=us&lc=en&dlc=en&product=3777182&tmp_track_link=ot_search
Oct 27, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
Paper jam message - no paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 12, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
Cannot find the replacement cartridge for my HP Photosmart Plus B209a-m printer. The black (564) cartridge on HP site is for the smaller cartridge. I can find the smaller (564) and the 564XL (which is...
Are you using genuine HP cartridges?
According to HP, the two cartridges for your printer are the 564 and the 564XL. Either cartridge will work.
HP does not offer another size.
Take the black one out that's in there now and see what the Part # is... then do a search for it.
Oct 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
