Question about Sole Fitness Sole E55 Elliptical
How to fix sole elliptical resistance? - Sole Fitness Sole E55 Elliptical
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
Why is the the resistance on my sole e55 remaining easy to spin regardless of which resistance setting I select?
Belt could have come off. if the belt did break or come of it would be very easy to spin pedals. Flywheel ( brake ) could have jammed up. Loosen the covers and look for the brake cable that's connected to the resistance motor. Then run the resistance up to 20. If cable feels loose , the brake is stuck. Sometimes you can pull on the cable and it will free it up.
Aug 30, 2014 | Sole Fitness Sole E55 Elliptical
Display Problem
Yes, you do need to either replace the entire console (4 screws) or the display board.
Dec 16, 2013 | Sole Fitness Sole E55 Elliptical
Sole elliptical display first said Level Err and now says Motor Error. What can I do to fix this?
follow this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
    • 2
Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
    • 3
Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
    • 4
Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
Oct 17, 2013 | Sole Fitness Sole E20 Elliptical
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
Why did I suddenly lose resistance and smell burning on my sole e55 elliptical?
proceed according. iF THE problem persis after you LUBEt, TIME to replace the old board deck belt.God bless you
Apr 04, 2013 | Sole Fitness Sole E55 Elliptical
Sole Fitness Sole E55 Elliptical Logo
41 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
