Question about Dell Dimension 3000 PC Desktop
Dell Dimension checkpoint [Dskt]. - Dell Dimension 3000 PC Desktop
4 Suggested Answers
  • 51 Answers
SOURCE: my dell dimension 8400 bios a03 fails to bootup
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Posted on Mar 10, 2009
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
SOURCE: when booting my dell optiplex dimension 270 i get an alert message of checkpoint [krst]
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Posted on Jun 02, 2012
Checkpoint dskt
Is this a new computer? Even if it is not I would go to the Dell website and click on the support button. Have your model and tag number ready
http://www.dell.com/support/contents/us/en/04/category/Contact-Information/Technical-Support
Mar 03, 2014 | Dell Dimension 3000 PC Desktop
Alert sound dimension
Please do a fresh install or try to use System Restore to go BACK before this problem happened.
Jun 08, 2013 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Dell 8300 failed at checkpoint krst
Try F12 or ESC or Del. Google search the error message by Make and Model of desktop.
Mar 04, 2013 | Dell Dimension 8300 PC Desktop
My dell 4600 says several previous attempts at booting have failed at checkpoint (rst)
sheila_barnu,
This error could very well be a motherboard failure. I found a Dell Community Forum link to where the resolved the error. Click the link below view.
Dimension 4600 Error
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2013 | Dell Dimension 8400 PC Desktop
Can not boot the system
if u realy want to make ur PC facotry fit....
visit my site
www.sureshayyar.110mb.com
Format Disk page
all detailas and necessary tools are available for download
Feb 05, 2010 | Dell Dimension 8400 PC Desktop
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Can't Do Anything... NEED HELP!!!
"Alert previous attempt at booting the system has failed at checkpoint emem {EMem}."
This is a No Post issue and if youre going to check the quadpack it will show yygg which indicates memory failure.
Quick Step : Reseat memory
If cust has more than 1 memory, test each memory on each slots until you find the memory that’s causing the error message and send a replacement for the faulty memory.
May 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 3000 PC Desktop Logo
178 people viewed this question
Alun Cox
