Question about Palm Zire 72 Handheld
Zire 72 does not recognize the SD card
After performing the hard reset, my device become "hanged" (the screen becomes blank) and it does not work. Then, i take the sd card out and soft reset, it works. However, whenever i put the sd card in the slot, the device cannot recognize and after soft-resetting, it becomes "hanged" again. ( I have installed Palm Zire 71 SD/SDIO Update but it still does not work.) Can U help me plzz?
  • Anonymous Mar 31, 2014
    I place an SD card in the handheld for backup but it says "No card inserted" ??
    Problem Solver:
  • 15 Answers
Have you used this card long and what size is it?
Posted on Jul 27, 2007
SOURCE:
Palm zire 72 will not syn with pc running win 8.1
You find a fix to that problem, and the (Palm) world will beat a path to your door. HP, Palm's new owner, has attempted a fix for Win7, but Win8/8.1 may become the impossible hurdle.
Mar 30, 2014 | Palm Zire 71 Handheld
Zire 72 resets on its own
Hello.
First, if you have not done so, perform a soft reset then a hard reset, if still a problem.
If a problem after the resets, your battery is most likely the culprit. I'd suggest to remove / insert or totally replace the battery.
If you are comfortable disassembling the Zire 72, here are some instructions found online:
http://www.macslab.com/charlies/Zire72Batt.html
Hope this helps.
Dec 31, 2009 | Cell Phones
How to insert a sim card into my Palm Zire 72
No sim card in the Zire 72. On-board memory on the motherboard only to store records not directed to or on expansion memory card.
Zire 72 battery changeout not designed to be user serviceable. Undertake at your peril (unless you are very steady handed, patient, and very very careful). The 72 is probably the most difficult of the Palms to change batteries. Go to: http://forum.brighthand.com
Navigate to the Zire 72 section and read the posts. There are even detailed photos and uTube movies that deal with changing the battery. I have used their forum for years. Lots of help there.
May 30, 2009 | Palm Zire 72 Handheld
Phone Screen becoming blank and hangs
Try formatting your Memory Card and if it fails, you should take it to the Nokia Care.
Jul 02, 2008 | Nokia 7610
Palm Zire 72
Make sure your card is an "SD" card and not "SDHC" which means you can only use expansion cards up to 2GB only. There are, however 4GB SD cards, but are now either hard to find or are more expensive. There are SDHC drivers around but you have to pay for those.
May 13, 2008 | Palm Zire 72 Special Edition Handheld
No display
Hello LyMaBa
Do you have an SD card inserted in the PDA?
If so remove it and restart your PDA.
Did the problem go away. If so, please, go HERE for the Zire 71 Expansion update or HERE for the SD/SDIO update.
You can find all the manuals for the Palm Zire 71 PDA HERE.
If you don't have a SD card inserted, you might want to try performing a WARM RESET of your PDA. Youtube has a video on this process HERE.
You can find instructions HERE for performing a reset ("warm" or "hard") on your Palm PDA.
You can find other software, info, downloads, etc.
HERE for your Zire 71.
If performing a "warm" reset doesn't work, try performing a "hard" reset.
*** WARNING!!! ***
YOU WILL loose ALL of your data on the PDA by performing a "hard" reset so make sure it's data has been synchronized w/ your computer software (Palm Desktop, Microsoft Outlook, etc).
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
Apr 09, 2008 | Palm Zire 71 Handheld
ZIRE 72 CAMERA
I changed the battery in my PDA recently and encountered the same problem. The fix for me was in the camera circuit board cable, the one at the top. For some reason, there is no actual plug for cable to go in, so I thought it just rested as is. The cable must actuly be pulled gently back towards the top of the PDA and then aligned with the contact pins from the circuit board. Again, it doesn't actually plug in to anything, but just rests against the pin connector. Be careful reassembling, because the ribbon cable can pop out of place easily (it essentially becomes "spring loaded" when put in place). Hope this works for you.
Mar 13, 2008 | Palm Zire 72 Handheld
TomTom one
Its more than likely that the data on your SD card has become corrupt or the card itself has become damaged / faulty. This can cause the tomtom to feeze on startup and doesn't even get past the loading process. You can "half" prove this by turning the tomtom ON without the SD card inserted. If you get the startup drums then a ' please insert SD card ' symbol on the screen , The card IS FAULTY . good luck. .................Hopefully , you backed up your SD card to your PC some time ago. If this is the case , you can just reload the files onto your SD card.
Feb 02, 2008 | Tomtom ONE GPS Receiver
Hard reset and recovering lost outlook data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 71 Handheld
Fatal Exception every time I sync.
Check docs to go and Avantgo Documents to Go and Avantgo are usually the culprit with me; if you use these try to reinstall. Check (delete and reinstall) "complex" applications, build to be able to use databases on the SD card. The final straw is the procedure suggested by Palm; -make a copy of your back-up from the palm directory; program files/palmone/van/backup. - do a hard reset - reinstall the applications one by one, hotsync after every install until you have found the offending application
Sep 11, 2005 | Palm Zire 72 Handheld
Palm Zire 72 Handheld Logo
352 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
