Question about Office Star Coat Rack - ME13 - Merlot Collection
ME13 COAT RACK - Office Star Coat Rack - ME13 - Merlot Collection
Tip
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
Kenmore Quiet Guard is clogged on the bottom. Leaking water.
take out the bottom rack, pop out the center. use a snake on the drain. if not aviable us a wirer coat hanger. the water should go down. to top it off ad some draino or something like that. but rises your dishes before you put it in the dishwasher. remember a dishwasher is not a garbage disposal. run the dishwasher again i wish nothing in it. that will flush out the drain. then your good.
Jan 02, 2013 | Dishwashers
I have a red coat rack in my daughters room and it clashes with the pink walls, do you have paint suggestions?
As an interior designer, I always recommend using gender neutralcolors in kids' rooms. I suggest thatyou paint your coat rack a muted color like grey, beige or white. The lighter the color the less likely it isto be mismatched with the rest of the room.
May 29, 2012 | Home
Where is the best place to put a hat rack?
In a restaurant the best place to put a hat rack is at the frontdoor or near the bathroom. In a home,you should put your hat rack next to the door so that your guests don't have towalk to put it down, and so that they remember to take it with them on theirway out.
May 29, 2012 | Home
How high should I mount my coat rack?
You should install your coat rock at the height that iseasiest for you to reach, without having the coats touch the floor. For most adults this is about five feet high.
May 29, 2012 | Home
Sparks from GE Microwave - HVM1540SN2SS
THERE SHOULD NOT BE ANY METALS IN A MICROWAVE WHEN THE UNIT IS RUNNING
If the unit paint is flaking and behind that flake is metal.. You need to throw it away or talk to your appliance guy and see if there is a speacial paint to coat the metal so you can use your MW
Jul 25, 2010 | GE Microwave Ovens
Fdw fault eco and fast flashing
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
Sep 02, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Office Star Coat Rack - ME13 - Merlot Collection Logo
751 people viewed this question
Top Office Star Home Experts
Donni Steen
Tom Chichester
Are you an Office Star Home Expert? Answer questions, earn points and help others
