Question about Maytag MER6872BAS Gemini Electric Kitchen Range
Electronic Control Panel
Several options on the touch pad control panel do not work. Some of the options and numbers work and others do not.
  • 5,911 Answers
If several options on the control pad do not work, I'm afraid you probably have an electronic control board that has gone bad. They aren't serviceable and have to be replaced. They can be a bit pricey, however. Most, run over a $100 with some running over $300. A lot of it depends on options and model. If you decide to replace the control board, the overlay (plastic piece with all the numbers printed on it) usually does not come with it, either. You can reuse the old overlay by carefully peeling it off the old control board and reapplying it to the new one. The overlay can run as much $30-$40 as well depending on where you get it. I hope you find this helpful.
Posted on Jul 11, 2007
SOURCE:
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Error code EO 14 kenmore elite oven
Unfortunately, the EO 14 code indicates a communication problem between the touch pad and the electronic control unit (the brain of the range). The control unit thinks that the touch pad's wiring is not plugged in. This can be due to a problem with the wiring or the touch pad slowly failing. Before ordering parts, check if the wiring is secure on the connector. Then check the wiring for continuity. If those are fine, the touch pad is usually replaced next. If the new touch pad doesn't solve the problem, then try a new control panel.
You'll need to give the full model number (4 more digits) for the range if you want to get the correct part numbers that may be needed. I found one parts list for the 790.97502001 and the 790.97509001 here: ftp://ftp.electrolux-na.com/prodinfo_pdf/lassomption/5995602603.pdf . The difference between the models is their color; this results in different part numbers for the touch pad.
I hope this helps.
Jun 07, 2017 | Kenmore Kitchen Ranges
The control pad only works on a few numbers.
Check to see if there is a ribbon cable between the touch pad and the circuit board. If there is, clean both ends with electronic contact cleaner, and re-connect.
If that doesn't fix it, you may have a bad touch pad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 11, 2017 | Microwave Ovens
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
Touch pad double click is not working. How to cure?
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Jul 09, 2012 | Dell Computers & Internet
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Feb 21, 2012 | Toshiba Satellite Computers & Internet
Several of the button son my control panel are not working (Cancel, fan off/on, pre heat, more options, convect, clean) Any thoughts on what needs to be replaced?
most likely going to be the touch pad these have a ribbon cable in them that connects to the control board and after time can go bad.... couple of sites you may want to try are
www.repairclinic.com
www.sears.com
www.apdepot.com you should be able to enter your model number and select the touch pad and get it ordered from one of these sites good luck to you
Jan 04, 2011 | Jenn-Air JGS9900BD Gas Kitchen Range
I am getting the E0 -F2- error code on my stove. I have unplugged for several hours; when plugged back in it worked for a couple of hours and the error code is back. What should we do. The burners work any...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected][email protected]
Jan 18, 2010 | Whirlpool GR450 Electric Kitchen Range
My touchpad on my mpc transport t2200 is not working as a mouse
Also if your ac adapter(powercord)is bad, the touchpad/mouse sometimes will malfunction and become impossible to use or not work at all.Start with checking your ac adapter voltage or try another charger first.
Nov 28, 2009 | MPC Computers TransPort T3000 Notebook
Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Mar 26, 2008 | Whirlpool MH7140XF Microwave Oven
Maytag MER6872BAS Gemini Electric Kitchen Range Logo
299 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
