Question about Casablanca Fan Stealth 3211T Ceiling
Scraping sound inside casablanca stealth fan
An momentary metal-on-metal scraping sound only at very slow speed when the fan is starting or stopping. Or when I turn it by hand. Obviously related to the rotation - there is one particular point in the rotation where the scrape occurs. The scraping does not involve the glass or the exterior housing.
The fan is several years old, and I think the fan blades are not perfectly level with the motor housing any more, So until the blades start to "fly" and level themselves out something (flywheel?) is hitting something at one point in the rotation. If I "adjust" the blades by hand to be more level this fixes it - once.
How do I find and fix this for good?
    Problem Solver:
  • 5 Answers
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Posted on Jun 19, 2009
  • 1 more comment
  • Tony Spafford Feb 12, 2011
    I believe this fan has a design flaw. I have talked to service people who allege this -- the thinking is that the blades are too heavy for the design, and consequently fall "out of level", as described above, after a certain number of years (typically when fan is out of warranty, of course!). This flaw necessitates purchase of a new flywheel. I would like to hear from anyone else who has had this same scraping-sound issue, because i have had it happen twice in ten years, and I want to take the matter up with Casablanca, and yo might want to as well. Admittedly the flywheel is only $15.00, plus applicable taxes and/or S
  • keithmcm3 Apr 13, 2014
    I have this same issue. I did correct it by adding small washers to sort of shim the flywheel and the housing but now its back. I have two fans. I only modified one unit about two years ago. Both are making noises now.
  • Karen Sullivan
    Karen Sullivan Jun 06, 2014
    Oh my gosh!! We have this same problem on two of our stelth fans. I just googled scraping noise on fan and I found this. Does anyone know who can install the flywheel? Is it hard to do? Thanks
How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
Casablanca stealth
Sounds like you need a new receiver.
Jul 19, 2014 | Casablanca Fan 3245A STEALTH® Brushed...
Casablanca stealth fan scraping noise
center of blade bracket mounts scrapping fan housing. Grasp blades and wiggle or shake them to make sure their not cockeyed. Turn it on then to check it.
Apr 13, 2014 | Casablanca Fan Dryers
Dryer drum makes a scraping metal sound
bushings at edges front and back are bad front ones are long and flat rear one is a small short plastic sleeve over center shaft. requires ordering parts from manufacturer and almost total disassembly
Dec 29, 2012 | Dryers
There is a scraping sound at slow speeds that appears to come from the front breaks. What is Causing the sound?
wear sensors on the pads-you need to pull one wheel and look to see how thin the linings are, better to replace them not than to wait until it is metal on metal and ruin a rotor.
Dec 25, 2010 | 2000 Toyota Camry
Casablanca stealth fan light scrapes against blade surround
There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
Jun 03, 2010 | Casablanca Fan 3245T Ceiling
The abs light just came on and the brakes make a noise
sounds like metal to metal scraping, time for new pads, rotors resurfaced, also bleed brakes
Oct 04, 2009 | 2002 Pontiac Grand Prix
Ceiling fan light flecker
Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
Clicking sound
The fan should be replaced. The bearings are getting worn out.
Jerry G.
Jun 06, 2008 | Casablanca Fan Stealth 3211T Ceiling
Casablanca Fan Stealth 3211T Ceiling Logo
1,962 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
