Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washer starts to run then trips the house breaker
Whirlpool ultimate 2. Has been overloaded twice recently. Does not go into spin cycle. Justbuzzes and then trips breaker.
  • 85 Answers
Probably severe arcing on motor commutator due to worn out carbon brushes
Posted on Jan 24, 2009
Whirlpool washer blows fuse
the pump motor is starting to seize up. It is causing the motor to work harder which causes heating of electronics causing the fuse to blow
Feb 21, 2012 | Whirlpool LSQ8543J
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Put washing machine on and it automatically trips
If it is tripping the breaker, the first question that has to be asked is how many other appliances do you have on the same circuit. When the washer goes to spin it will start to draw slightly more electricity than once its at a full spin(much like the energy needed to get a car moving is greater than once it is up to speed), but it is not enough to trip the circuit unless there the circuit is already near capacity.
Before attempting to check electric of the washer, check and remove items from the circuit. To know what circuit runs your washer you will need to take a pigtail or a radio and plug it into the outlet Go to circuit breaker box and turn on and off circuits until the radio goes out.. Once you acertain what circuit your washer is own, go throughout the house and see what circuts are shared with the washer. Unplug any that are shared with washer. Your Hotpoint needs no more than 15 amps to run but if your overloaded on the circuit, the spin is enough for it to trip the circuit. Try washer and see if you go through the full cycle.
Oct 13, 2009 | Hotpoint Washing Machines
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
After wash cycle the machine just hums and then trips circuit bre
Most likely a motor coupling. Take off the cabinet by removing the screws around the control panel. Take of the pump by releasing the 2 clips on the top and bottom. Take off the motor with same 2 clips but they are probably screwed on as well. the coupling is right there. They will break if a machine is overloaded.
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Not completing the wash cycle
Does this happen every time or once in a while? If it happens everytime, I would guess there is a shorted spot in the timer. If you can put it into the spin cycle manually, then the motor is not shorted. It will be hard to diagnose it from long distance, but if it is tripping the house breaker it has a dead short somewhere. If it only happens sometimes, check to see what else is on the circuit that might be running at the same time. It pulls the most amps when it goes into spin, spiking around 16-20 amps. If you have other things running on a 20 or 30 amp breaker it could just be the curcuit is overloaded at that point or the breaker is weak. If we can narrow it down to the timer, it is a pretty simple repair, but some of the timers are pretty expensive. Post back with the exact model number if you need more help.
Oct 18, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER AGITATES WHEN SUPPOSE TO SPIN
Faulty spin windings on motor. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
