Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover 5470-900 no longer contacts carpet with beater brush
My Hoover WindTunnel vacuum no longer contacts the carpet with the beater brush and has very little suction for the carpet.
It works fine when I use it with the accessories.
I have replaced the beater bar and have taken apart the front plate pieces to make sure that there is nothing blocking airflow. While I have the front plate stuff removed, I checked for vacuum power at the point that the hose comes down and it is still very powerful.
No matter how low I set the height setting, the beater bar does not come in contact with the carpet.
It feels like I am dragging the unit across the floor without wheels, but nothing appears broken or unusual.
thanks for any help
  • estaszko Jan 31, 2009
    Are there any instructions for doing this repair available?
  • Anonymous Mar 18, 2014
    remove bottom plate to remove beater bar
  • 66 Answers
Your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Posted on Jan 24, 2009
  • 98 Answers
I have as of yet found any repair guide for any of the Hoovers if I find anything I will let you know
Posted on Jan 31, 2009
Beater brush will not turn even with belt intact
is there any loose pieces of carpet or twine wrapped around central bar.
Dec 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
The suction is quite poor, also definite burning smell after normal use. we only have about 3 years would it be the engine
I would check the drive belts for the beater brush and make sure the beater brush itself is free to move in the holders. Clean the beater brush of all debris and add a bit of WD40 on the two ends between the brush and the holders.
I do not charge for my advice. : )
Paul
Sep 18, 2010 | Hoover S3755 WindTunnel Bagless Canister...
Hoover beater bar is loud & vibrating.
brush roller /agitator needs replacement. part price : $25.00 to $ 30.00
May 06, 2010 | Hoover U6630-900 WindTunnel Bagless...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Beater bar
There may be a shutoff switch, located on the hood, that shuts off the agitator to permit bare floor cleaning. Return the switch to carpet mode.
Sep 29, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
544 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
