Question about Frigidaire PLMV169DC Microwave Oven
PLMV169DCD Frigidaire Microwave Over the Range Oven Quit
The control panel was intermittent, especially when the ambient temp was lower- like overnight. When ambient temp was a few degrees higher, it would come back to life.
Now, it's completely dead.
Can you repair it, or should I buy a new control circuit board?
Thanks
  • rv10164 Jan 26, 2009
    Yes, that's correct. Dead-nothing-nada.
  • William Miller
    William Miller May 11, 2010
    Is it dead, meaning no
    display, no light when you open the door and no beeps when you press a
    pad on the keypad?
  • Frigidaire Master
  • 9,098 Answers
We have the service / repair manuals for these models and have uploaded them to our site to help you.
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
I would first suspect the C/T fuse or the oven thermal cutout.
Accessing some components for testing will require you to remove the oven from the wall.
The manual covers this as well.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Please write back if you need further help.
Posted on Jan 26, 2009
How to repair a Frigidaire PLMV169DCD rangetop microwave oven that no longer heats food
Good Afternoon Friend,
I see you want to know how to repair your Frigidaire microwave, model# PLMV169DCD. Repairs on microwaves are typically not a do it yourself repair. I suggest contacting your local authorized technician for further assistance. They have been trained specifically on your appliance and will know exactly how to repair your microwave. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Microwave Ovens
My Frigidaire oven model PLMV169DCD has developed a defect
The only real issue with the control board that could cause that is a failing relay or bad connection, both of which I can repair on a control board for $54.95, which includes insured return shipping.
The first thing I would do is test the outlet. A toaster or hair dryer are good devices to use.
A microwave must be on its own breaker, or at least not on the same breaker as a high-current device (stove) or a device that causes spikes on the line (fridge, freezer).
It's possible you have a failing magnetron or high-voltage transformer, but I would need to discuss it to narrow it down.
For free additional DIY help and details, feel free to e-mail me directly from my site. Remind me of your full model number and detailed symptoms.
William E. ("Ed") Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 26, 2017 | Frigidaire PLMV169DC Microwave Oven
Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Electrolux / Frigidaire owner's manuals and installation instructions
here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
Dec 03, 2011 | Frigidaire PLMV169DC Microwave Oven
How do I get to the control panel of my Frigidaire PLMV169DCD?
When you open the microwave door, on the right side should be two philips head screws. Unscrew those to remove plastic cover and there will be control panel behind which is secured with 4 screws.
Jan 05, 2010 | Whirlpool GH7145XF Microwave Oven
Frigidaire micro plmv169dcd not working
test it with a meter it has a small wire inside and, sometimes can not be visually checked
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Control pad does not repond
hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
442 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
