Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Lift master garage door opener. Motor makes noise when switch is hit likes its running but chain/sprocket doesn't move and the door is stuck open. Chain is on sprocket. Not sure if the motor is frozen? but when the switch is hit, it makes noise for going down, hit switch again and it makes noise like going up, hit again it goes off. But no door movement/no chain movement. Does it need a new motor/entire unit or is it something simpler? Any insight would be helpful. Monte
  • 2 more comments
  • Anonymous Feb 15, 2009
    same issue
    Same problem, pulled the cover off and the worm gear is stripped. Chamberlain website shows replacement gear is available. Hopefully not to hard to replace this gear.
  • tomc28 Feb 16, 2009
    When you say "Take The Unit Off The Ceiling To Replace The Gears" do you mean the entire Chain/arm assembly also?
  • 240cpa May 11, 2010
    Have you checked to see if the power out release that detaches the door from the chain was pulled? This would be the handle attached by a cord at the end of the drive next to the door. If it was released, reset the handle so the door and the drive are engaged.
Power is on, the door will go up about 12-16 inches and stop, but with help it will go all the way up,but !!!!!! when i hit the button to make it go back down it only moves about 12 inches whats up with this!!!!!!!!!!!!!!!!!!!!
Posted on Feb 28, 2010
I had the same problem. Took the cover off of the opener and found that the gears were stripped on the unit. Motor was fine. You can order gear replacement kit for the unit. They are a plastic type sprocket and worm gears. The kit comes with spindles and all necessary clips. You have to take the unit off the ceiling to replace the gears, but the process if very easy to do. Parts kit about $40 on line, much cheaper than a new door opener. Total process took less than 2 hours, including getting the unit down and back up again.
Posted on Jan 25, 2009
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't lift when push button. Makes loud
if this is a chain drive,is the chain so loose that the chain is jumping on the sprocket? this would cause a lot of noise. if this is the problem just tighten the chain.
Nov 25, 2009 | liftmaster Chamberlain Garage Door Opener...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman door opener brand new wont work?
Sounds like the drive gear is stripped. Remove the cover and take a look. It is white nylon and is just in front of the motor.
Jul 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open
You can fix this by loosening the chain enough that you can lift it off the sprocket. Then run the opener until the sprocket turns counterclockwise and stops. Now with the door in the open position replace the chain. This will get the chain running the right direction. You will have to adjust the open and close limits along with the force adjustments but that will all be covered in your owners manual.
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman opener motor works, but chain does not move.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Lift-master chain drive garage door stuck at the protection bolt
you will have to find were the chain is binding look around the drive sprocket and check the chain to see if it is tight at the bottom or top this will tell you were to start looking for the problem.
Sep 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
484 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
