Question about Kenmore 24032\24036 Top Load Washer
Aggitator is stripping out
Kenmore Elite top load washer. During the wash cycle when the aggitator is turning, it is making a louder noise than usual and I think that it is stripping out. When I turn the aggitator when the machine is not on, it turns then strips. How hard is this to fix?
  • jjatnip Jan 24, 2009
    Thanks!!!! Very, very helpful, but how do I get it apart?
    Novelist:
  • 101 Answers
It's easy, your agitator dogs are bad. They are little teeth that sit inside the agitator. If you remove the top of the agitator you will see 4 small gizmos that sit inside there. They have teeth that catch the teeth on the agitator and stop it when it agitates. The teeth on the agitator dogs are just worn out. They cost around 7 dollars from your local appliance repair shop and are easy to replace. Just pull out the housing for the dogs and replace them. You buy them in a set of four. Let me know if you have any other questions and let me know if this was helpful. Good luck and have a great weekend.
Posted on Jan 24, 2009
  • Dan Harris
    Dan Harris Jan 24, 2009
    It should be pretty easy, it's hard to say if I am not standing right there but once you get the top of the agitator taken off you will find that there is a screw with a bolt located inside. Simply loosen the bolt until it comes out and the agitator will come out. You should be able to get the agitator dogs out from that point. Let me know if you have any other questions. Good luck.
My top loading frigidaire washing machine barrel spins during wash cycle and the aggitator is going as well how do i fix it
Hello fire_rod - From what you have described it sounds like either the transmission is failing or the trunnion, which secures the tub to the transmission shaft has broken. Contact a professional to move forward accurately.
Dec 16, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore model 80 washer won't aggitate but spins and drains without issue. The aggitator tries to move but acts like there is a gear stripped or something.
you will need to purchase an agitator replacement kit for your washer and, the clutch will need to be replaced as well. these components are damaged and, replacing them will restore your units agitation functions.
Jun 07, 2009 | Kenmore 15944 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
AGGITATOR WILL NOT TURN AND WASHING MACHINE WILL NOT SPIN
Hi. you will need to replace the clutch assembly and the drive shaft gears as well. these components allow the agitator to agitate during the wash cycle and if they are stripped or locked, due to a mechanism failure, it will not do its job correctly.
Please rate and god bless:)
Apr 02, 2009 | General Electric WJRR4170GWW Top Load...
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Whirlpool washer makes loud noise but aggitator doesn't even turn
a load of Jeans or pants is hardest on washing machines , you probably broke the belt for the aggitator
Dec 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
