Question about COBY-PERSONAL & PORTABLE Bluetooth Speaker System For IPad/IPod/IPhone / Mfr. no.: CSMP135
Pairing code i need the pairing code for bluetooth
Trying to bluetooth pair a Cowan s9 to a jbl charge
Bluetooth connection should be in Settings menu. From there, choose Bluetooth then turn on the Bluetooth transmitter by touching the second option from the left at the bottom of the screen (Bluetooth symbol). After that, press the locate Bluetooth button (the leftmost choice). Make sure your headset is turned on. The player should list your headset once it finds it. There might be a button on headset that needs to be pressed in order to pair it with a device. Once the headset is located it should ask you for the pairing code (usually 0000). If the code is different for your headset, press the rightmost button at the bottom of the screen and enter the code.
Nov 07, 2013 | JBL Charge Portable Wireless Bluetooth...
Need bluetooth code for eonon d2216
D2216 Bluetooth code/pin is 5802
Apr 14, 2013 | Car Audio & Video
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
The default pairing code for most bluetooth devices is 0000.
Try this to see if it works.
Thanks for using Fixya
Dec 14, 2008 | LG Shine CU720 Cellular Phone
COBY-PERSONAL & PORTABLE Bluetooth Speaker System For IPad/IPod/IPhone / Mfr. no.: CSMP135 Logo
47 people viewed this question
Top COBY-PERSONAL & PORTABLE Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a COBY-PERSONAL & PORTABLE Audio Player and Recorder Expert? Answer questions, earn points and help others
