Question about Invicta Highline 9777 Wrist Watch
I need a replacement band or button deployment clasp
My deployment clasp broke
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
The spring in the clasp has broken so the watch band will not stay closed. How can I fix this problem?
replace clasp is the best option..if clasp has 2 buttons on it these can be a easy fix but they always break again so i would replace clasp section or even all the bracelet for the watch .you will need model and serial numbers of the watch then try manufacture or ebay or a repairer
Mar 25, 2010 | Watches
Anne Klein 10/5875 Y121E
You do noy need an exact Anne Klein band as all watch bands are made to specific measurements.
You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one.
Do not forget to rate, please.
Feb 27, 2009 | Anne Klein 108293SVBK Watch
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
Invicta Highline 9777 Wrist Watch Logo
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
