Question about Bionaire BCH9221UM Ceramic Electric Heater
Bionaire space heater bch9212 digital display not working
The display goes out 2 - 5 seconds after the unit is turned on
2 Suggested Answers
  • 2006 Answers
SOURCE: I have an Bionaire BPH1520
AUTO SAFETY SHUT OFF
The heater has a built in safety device which
will switch off the heater automatically in case
of accidental overheating. It can only resume
operation when the user has reset the unit. For the
BPH1520 (OH)will display in an overheat situation.
To reset the heater:
1. Unplug the heater and wait for 30 minutes
for the heater to cool down.
2. After the 30 minutes, plug the heater in
again and operate normally.
fOR FUTURE REFERENCE HERE IS A COPY OF THE OWNERS MANUAL
http://www.bionaireuk.co.uk/Manuals/MANUALS/BPH1520-UK_43_91313392.PDF
Posted on Jun 07, 2011
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Heater unit # BH3930-u
Here is the manual for it:
Read it carefully ur problem will be solved..
http://www.bionaire.com/bionaire_US_manuals/BH3930.pdf
Goodluck,
Don't forget to rate me as fixya..
Jan 29, 2008 | Bionaire Tower Compact Heater
My Bionaire BCH9221um wont turn on.
You might want to open it up and check the thermal fuse. This is usually a small cylindrical device with a cone at one end and wire leads coming out of both ends. It opens permanently when it gets over a certain temperature, and sometimes will open prematurely. Check it for continuity with an Ohmmeter. If it is open, then it is the problem. You can usually read the temperature, or a part number on the side. Look it up on the web, or go to your local electronics parts store. You can get one for a buck or two. Replace it by crimping it on to the wires, do not attempt to solder it, as the heat will likely destroy it.
Good Luck.
Nov 26, 2014 | Bionaire BCH9221UM Ceramic Electric Heater
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
Bionaire BCH9212 does not produce heat
These Bionaires (including your 9212 and its taller version, the 9224) have a small temperature safety relay mounted slightly above the ceramic heating elements. Its purpose it to shut off the elements if they overheat, which I would assume would happen if the fan stops working or possibly if the outlet to the front becomes blocked (and these ceramic elements, which are like a radiator core, do get a lot of dust accumulated on the inside which will block air flow). The sensor is a small unit with exposed contacts and if these contacts open (driven by the temperature sensor connected to them) or if these contacts do not have good contact (say by dirt or oxidation build up that makes them effectively fully or partially open) then the ceramic elements will not work. My best suggestion to explain your problem is that the contacts on that safety switch became dirty during storage. The only way to verify that (and possibly repair the unit) requires taking the outside shell off and cleaning the contacts of the safety switch with either a small, fine file (like the old ignition files) or maybe fine emery cloth.
Nov 30, 2011 | Bionaire Heating & Cooling
I have an Bionaire BPH1520 Micathermic Electric heater which will not heat up. I turned it off after use and now will not heat up when switched on. Digital display still lights up? Is there an internal...
Jun 07, 2011 | Bionaire BPH1520 Micathermic Electric Wall...
ON OFF BUTTON KEEPS CLICKING,HEATER WONT STAY ON
I do not know what kind of unit it is but make sure where the air goes is clear and clean. Post me back if I can be of more help.
Dec 01, 2008 | Bionaire Heating & Cooling
Bionaire filter replacement- reset indicator
It worked - the solution to press sleep and the power button simultaeneously worked! Air cleaner then reset to 99%. Thank you Harbourman!
Oct 31, 2007 | Bionaire BAP1175-U Air Purifier
Bionaire BCH9221UM Ceramic Electric Heater Logo
433 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
richie46
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
