Question about Fellowes 3011001 Shredder
Fellows S701CM shredder won't respond
The shredder just all of a sudden won't do anything. When I put a sheet of paper in the slot, it usually cuts on and shreds. Just sits there with no response at all. Nothing in reverse either. I cked the power source & it's ok. Is it dead?
  • Anonymous Apr 19, 2009
    CHECK THE MAIN GEAR ON THE SHAFT OF THE DRIVE MOTOR..FELLOWS DOSE NOT OFFER THIS GEAR ANYMORE BUT WILL SELL YOU A REMAN. UNIT . SUPRISE..ANYONE KNOW OF A SOURCE FOR THIS PART?
  • 58 Answers
Unplug in and check the fuse in the back side of the shredder
good luck
Posted on Mar 26, 2009
Keeps stopping with overload light on. How can this be fixed
The most likely cause is that the shredded paper, has tightly wrapped itself in the blades. One possible cause is by shredding labels (like Avery Labels) or any paper which has adhesive on it. (Causes it to attach the cut pieces to between the cutters.) It reaches a point where there is so much bound up on the blades that even a single sheet of paper will cause an overload. The fix is simple to describe, but difficult to accomplish. You must go in and manually remove all of the paper bound up in the blades. It's not easy, I found that using a needle nose pliers worked best. Lot of digging and tugging (paper will pack between the blades very tightly). Sometimes a small, slotted screwdriver will aid in being able to pry out bits and pieces (it's not going to come out in anything but small chunks; at best). Don't forget to unplug your shredder before you start; those blades are sharp. This happened several times with my last shredder *Royal), but not once with my current shredder (Fellows). I tend to believe that the better quality shredders are worth the extra money. But any shredder will become a problem if you shred labels (like Avery) or paper products that has adhesive on it. (Another common mistake is shredding junk mail that has any kind of adhesive associated with it. Best to open and check first.) One other thing, ALL shredders need to be oiled on a regular basis. They make special oil for this, you can usually find small bottles of it at Wally World or the like. Best practice is to squirt some shredder oil in a serpentine pattern. over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin. (Important for the life of your shredder.)
Aug 29, 2014 | Royal 150MX Cross-Cut Shredder
How to open fellows s701 cm shredder?
There are six Phillips head screws around the perimeter of the underside, plus one more hidden screw in the center under a label. Then the cover just lifts off ...
May 18, 2014 | Fellowes S701CM Shredder
Sherder also cus off on shreder has no cutting power &no suction
Hi - Shredders don't have suction, but if the blades have gone dull, it can't pull the paper in because it can't cut it. Try one sheet or even half a sheet.
The other possibility is that you are not putting the paper against the paper sensor or the sensor is brokern or blocked. This sensor is usually in the center of the shredder slot. Test it by putting a piece of paper a bit down and seeing if the "on" light comes on.
If the blades are dull, it is probably cheaper to get another shredder on craigslist or staples. I don't know, but am assuming this is a small home office unit.
If the sensor is not working, you can try to clear it.
Investment in repair depends on investment in the scanner. Tell me more and i'll try to research it a bit.
Jan 18, 2014 | Office Equipment & Supplies
My fellows PS-65S electric eye has been cleaned and still won't take paper to shred
I have had the electric eye come out. they kind of lock in there. I have had a couple push back. I had to take glue the electric eyes into the slot. like I said I have had this happen on two fellows shredders.
good luck
Jul 18, 2012 | Office Equipment & Supplies
HOW DO I OIL MY FELLOWS P-35C SHREDDER
You can squirt some shredder oil onto a piece of paper & shred that paper.
Mar 31, 2011 | Office Equipment & Supplies
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Mar 29, 2008 | Fellowes DM8C Cross-Cut Shredder
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
Fellowes 3011001 Shredder Logo
454 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
