Question about Canon BubbleJet i550 InkJet Printer
Cannon I550 flashes amber 7 times.
How do I clean the waste pads? Where are they?
  • Canon Master
  • 19,396 Answers
Check the link below and follow thoroughly instructions.
Canon Printers Waste Tank Error Message Reset Solution
Posted on Jan 25, 2009
  • Canon Master
  • 13,433 Answers
The printer has a pad in the bottom which absorbs the waste ink.
After they have been cleaned or replaced the printer needs to be reset
Posted on Jan 24, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Follow the instructions carefully, get the printer to move the cartridge harness to the position to where you can remove the cartridges, remove the cartridges and pull the plug on the printer, now look in to the printer you will see the harness you just took the cartridges out and running through the harness is a chrome bar and remember the bar, now look up just a bit you will see a thin maybe a quarter of an inch wide a plastic strip that runs accross the printer and through the back of the cartridge harness and is supported on each end and one end has a tension spring remember the plastic strip, now on the left hand side at the front of the printer when you look in the printer you will see a gear reach i with your fingers and turn the gears turn them to make sure nothing is obstructing them if you make a full rotation it should be ok, now remember the chrome bar you will need to go to an automotive supply store and get a small bottle of hydrolic oil you will also need some Q tips, now dip the Q tip into the hydrolic oil and rub it on the chrome bar, do the whole bar and do not add more oil to the Q tip their will be enough to do it, then take your hand and grab the cartridge harness and slide it back and forth on the bar them bring it back to the position it was, now remember the plastic strip, now you need some 99% isopropyl alcohol it does not have to be 99% but that is all I use, and a Q tip, dip the Q tip into the alcohol, now bend the Q tip end at 90 degree's and gently rub the Q tip on the plastic strip do the whole strip both sides and move the cartridge harness to clean back there, the secret to this is to keep the Q tip clean so you could go through a few, when that is done reinstall the cartridges and plug the printer back in, go to start > control panel > right click the mouse over the printer icon > properties > maintenence > print head alignment and do an alignment, then try it again, if that did not work you could have a main board problem and I'm sorry to hear that but you will need a new printer and do stay with Canon they are the industry leader, I'm sure your printer knowledge went up a few levels in fact a lot of tech's won't even know this, take the printer service repair course you half way there ha ha, do hope this had helped you out this was not easy and good luck.
  • Rylee Smith
    Rylee Smith Jan 24, 2009
    When you have cleaned it then follow the procedure to reset it :
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    Thanks
    Rylee
  • 10,515 Answers
Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 27, 2009 | Canon BubbleJet i550 InkJet Printer
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
7 flashing amber lights
You do 2 things. See the service manual
http://www.eserviceinfo.com/download.php?fileid=38984
Dec 06, 2008 | Canon BubbleJet i550 InkJet Printer
I get error code 5100 what does this meen???
If you are using a Cannon i550, code 5100 is a carriage error, check the timing strip for contamination (plastic strip about 1/4" in width) If the unit is not homing, check for obstructions.
Just FYI:
If you need to put the printer in service mode, you can do the following:
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
If you need to empty the waste tank:
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this was helpful, didn't see the printer type posted which made it harder.
Jul 29, 2008 | Office Equipment & Supplies
Waste ink almost full
Try this following method on how to reset the waste ink
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above,
1. Turn off printer
I hope you solve your problem and give me a good rating
thanks
Apr 23, 2008 | Office Equipment & Supplies
Cannon Bubble Jet 4100 Printer
Does the machine beep 5 times and flash both the power and error lamps? If so then the Waste Ink tank/pad is full and needs to be cleaned and the printer counter reset.
Sep 24, 2007 | Cannon i70 Printer
Canon BubbleJet i550 InkJet Printer Logo
35 people viewed this question
old marine
old marine
