Question about Dell 966 All-In-One InkJet Printer
My AO 966 printer has stopped working for the third time.
I updated my computer last year and it only comes with Vista and Microsoft has not even began to get the bugs out of it. I recieved a messag that Microsoft had made a update that had stopped the 966 from working.
I am trying to get a answer to the fix now. In the mean time I have hooked my Hp C4180 back up.
  • 628 Answers
Stick with the HP or go back to XP if you can. Vista is buggy. You might try to reinstall the printer driver if not already done.
Posted on Mar 10, 2009
Network sharing center won't stay open
just been fixing a window vista laptop with problems
Microsoft stopped supporting windows vista years ago
no updates or upgrades
you are at base service pack one
and computer should have been updated to service pack 3 years ago
from service pack 3 a windows 10 upgrade is possible
try an ethernet or usb wifi connection .
.see if the computer will run the way you want it
any windows vista computer is a x32 bit system
with upgrades can run x64
x86 is the current
if you are running anything higher than 32 or x64 software the computer will be slow sometimes freeze or shut down
vista came out same time as and dial up internet
and early broad band
vista can run office 95 but windows 2000 is stable
May 29, 2016 | Microsoft Windows Vista Home Premium with...
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
Wont print, says ink is low.. ...but will print
problem could be not compatible with the windows program
most windows vista will not except any printer made before windows vista.
Apr 08, 2010 | Dell 966 All-In-One InkJet Printer
Dell Photo 966 AIO won't print after trying to download Adobe 9
You need to restore your computer to a date previous to your Adobe 9 install. Click the following:
Start-Programs-Accessories-System Tools-System Restore. Choose an available date prior to the date you installed the problematic software.
Nov 07, 2009 | Dell 966 All-In-One InkJet Printer
We have a Dell Photo 966 and are not able top
Did you do an in place upgrade or a custom install of Win7? What is your printer status in the printer and faxes window? If you see an exclamation point, it may be that you need to install an updated driver. Often you can let the Windows troubleshoot device fix the issue successfully. In that same printer and faxes window, check if you have files in the print spooler. You may need to clear the old queued files.
If you can't delete them directly the spooler window, you may need to stop the spooler and restart it. In XP, this was easy in the command prompt window (Command run works but you do one line each time. In Vista and probably in Win7 you'll have to do this as administrator. Assuming the spooler commands haven't changed, type "net stop spooler" (enter) then "net start spooler" (enter) without the quotes. (I know this worked in 2K and XP; I've never checked it in Vista or Win7.)
In addition, many USB printers need to have the USB cable removed from both the printer and the computer when you turn off and unplug the printer to reset the printer.
A final step to try is running the following patch from Dell: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R166245&SystemID=PRN_ALL_A966&servicetag=&os=WLH&osl=en&deviceid=11887&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=2&libid=40&fileid=224506; this totally removes the printer from your computer. Then you can reinstall it after rebooting the computer (wait until it tells you to restart).
Nov 01, 2009 | Dell 924 All-in-One InkJet Printer
Dell 966 printer wont scan
The all in one solution software you used in XP doesn't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Dell 966) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Dell 966 All-In-One InkJet Printer
Installing lexmark x125 multifunction printer
Vista seems to be incompatable with the currently avalible drivers
Feb 29, 2008 | Lexmark X125 All-In-One InkJet Printer
Connection to my Computer with Printer
Hello fosstone
Are you running windows Vista? Was the printer working at one time? If using Vista try this. Open Control panel, open system. Click on hardware tab, click device manager button. Scroll down till you see the yellow ! point. Right click on it once & choose update driver (a left click). A pop-up window will open. Choose No not at this time, click next. Click Install from a list or specific location. Click the Browse button. Scroll to your C:\ drive & click on it. Scroll down to the folder Window\system32 & click on it once. Click OK. With any luck windows Vista will re-find your USB & your printer.
Lastly, Microsoft may have created a fix in Vista update (KB940199). So run Windows Update just to be sure.
Please drop by & let me know if this helped.
Good luck fosstone!
Have a good day.
please vote...
Feb 26, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell A-966 All-in-one Ink Jet Printer
Goto control panels
open printers and faxes
Tell me everything you see in there.
How is the printer Connected?
Nov 13, 2007 | Dell 966 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
