SOURCE: My Garmin Nuvi 255w Car Gps
You must call Garmin at 1-800-800-1020 they will walk you through plugging in nuvi to your computer (must have usb cord) and it will upload then go to my computer and choose garmin drive then click garmin folder and either find the folder they say or make new one like I did with the guy on the phone and put in code. The only information needed is the numbers on the bottom of the device.... super fast fix!
SOURCE: my garmin nuvi 650 will not go to next screen it
have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with
the unit off,and unplugged, try pressing and holding your finger on the low right
corner of the screen and slide the power switch to the on position
until you see the message "confirm if you really want to delete
all user data?" hit yes and let it restart. then it will set up the
nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
SOURCE: just used garmin nuvi it worked fine went into the
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your
device to factory settings or delete any map updates. The reset button will
switch your device off if you are unable to switch the device off by the power
button. It will not erase any data on the device.
The reset button on your nuvi will switch
the device off. The reset button can be used to switch your device off if the
screen is frozen and you are unable to switch the device off by the power
button.
To reset a nuvi 2xx:
To reset a nuvi 3xx or 6xx:
The device will now switch off.
Make sure to charge it fully.
SOURCE: Ok so my Garmin nuvi 1300 is frozen the screen
A Garmin Nuvi 1300 that won't start, or is
acting erratically is symptomatic of having corrupt
firmware.
To
correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck,
then updating your Nuvi firmware.
Follow
these three steps to take to get
your Garmin Nuvi 1300
running like new:
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
