Question about RCA D61W20 61" Rear Projection Television
Cant find format control for zoom
I tried to turn down the volume with out remote and the zoom increased in size, twice the original size and we can not find the format control to down size the picture we are frustrated and its horrible watching only bodies or half a head come on somebody help us with this problem......
Theres a button on top left of remote by the power button. i dont have this tv anymore but i had same problem if you push that button it should change i forget what button name was though.
Posted on Jan 24, 2009
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Peoples heads are cut off on my 52 inch screen. how do I format the picture
Try to adjust it in to your remote by choosing the menu button and try look for the picture setting or picture size when adjusting it you should press the volume control in your remote up and down, it may help thank's.
Jul 09, 2011 | RCA R52WH73 Projection Television
My 51f59 tv is zoomed in too close to see the all of the bottom
look for a button on remote called format , aspect or picture size and press it till the picture fits the screen
Feb 04, 2010 | Hitachi 51F59 51" HDTV Projection...
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
Zoom adjust on RCA D52W19 tv WITHOUT remote
if you have the original remote, your right and left arrow keys adjust the size, if size changes during commercials, get into your options and turn off the auto-size option, if you don't have the original remote, you must find a universal with proper mright and left arrow buttons.
Sep 15, 2009 | RCA D52W19 52" Rear Projection Television
Volume increases to 30 can't turn down
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
Sep 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Zoom control
Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
