Question about LG 42LC2D 42 in. LCD HDTV
42lg3000 stuck on standby - LG 42LC2D 42 in. LCD HDTV
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Dec 15, 2015 | Televison & Video
Stuck in standby mode on Fisher RS-911A receiver
Does it power up or straight to standby? If it is on but in standby it could be speaker protection issues...check speaker wires and/or speakers for issues. If it's straight to standby and no power, it's repair shop time.
Jan 02, 2014 | Fisher Audio Players & Recorders
Tv stuck in standby mode
When a TV is stuck in standby mode often means that there is a problem with its power supply or even in the horizontal output circuitry. May be a component with short-circuit in the RGB output driven by the flyback transformer or a rectifier diode in the power supply output.
I hope having helped you.
Sully
Sep 27, 2013 | Sony Televison & Video
How do you use the USB port on the 42lg3000
Download the user manual to this set by this link. It has all details. http://www.tv-manual.com/manuals/lg/LG_42LG3000.pdf
Jul 31, 2013 | Televison & Video
As such, the main culprit would be the power supply. Check the Caps, and power diodes. If you don't know what you're doing get some help from a professional, you will gain the tv and your life.
Jan 16, 2013 | Televison & Video
42lg3000 reset codes
Unplug this TV from AC mains wall socket, and replug it after 5 minutes or so. This should make it a hard reset.
If you want more details, download its user manual from here and refer it.
Jun 09, 2012 | Televison & Video
WHERE CAN I DOWNLOAD A USER MANUAL FOR A 42LG3000
Try the LG website itself u should able to download the owner manual,if your tv model still in the selling market.If not give LG a call talk to their costumer service department pay them a fee they will sent it out to u.
Nov 24, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Lg 42" lcd tv (42LG3000) TV is wall
White screen with good audio. before buying pcbs & such. try my repair method.. you need to get the lcd unit off the facia & then remove the front lcd metal frame. at the top of the screen you have 2 thin pcbs - chances are that the ribbon cable got at least one track unbonded. first off put some double sided tape under the pcbs to stick then to the frame - that'll take the bend out of those pcbs !! next put cellotape over the ribbon cables. i then cut 6 pieces of sponge 15mm thick & wide as the ribbon cable & glue to the tape on the ribbon at what would be the top edge of the screen (covering the point where ribbon meets pcb).. put the metal frame on top edge first to keep the sponge straight !! put it back together & fire it up. if it still aint working you may need a tcon pcb (little square one at the top). this fixed my 42lg3000 but can work on others with same fault !!
Mar 16, 2011 | LG 42LC2D 42 in. LCD HDTV
Cd shelf unit stuck in standby
my rca 5 disc changer stuck in standby
Dec 12, 2008 | Audio Players & Recorders
LG 42LC2D 42 in. LCD HDTV Logo
18 people viewed this question
Computer Repairing
Computer Repairing
