Question about Gateway MX6453 Notebook
Broken screen My son stepped on the top of his lap top and the screen is damaged. Half of the screen looks fine the other half not. Is it worth getting it repaired because everything else seems to be working fine. The non-experts I ask said it would probably cost more to have it fixed than buying a new one. Thanks, Tom
  • 63 Answers
Dear burke833,
You can easily buy one off of ebay install it yourself and fixing it. Just search on ebay how to open and replace a laptop screen. It would cost much MUCH less to fix it yourself for a 15.4" inch screen would cost around $80. Hope this helps!
Posted on Jan 27, 2009
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Only half of the screen is working
Most likely it is the screen that is bad and it probably can't be fixed however it is worth opening up the TV and getting to the T-CON board, wwhich drives the LCD display.
The T-Con is located at the top middle of the TV looking from the back and it's usually covered by a shield cover.
You can tell it easily by its location and the large cable that goes to it from the main board.
The board's ID should be 4046HSC4LV3.3 (make sure to verify that once you get to it!) and it should look like this:
What you are looking for is the white cable that goes out from one of the two connectors at the top of the cable and goes into the LCD display.
I'd recommend pulling out the one that's on the side of the half that does not work and inspecting it for burns.
You may also swap it with the other.
The odds of succeeding are low, even if it is burned and you replace it, but a few times I was able to fix a display like that.
For more help feel free to check at our site www.coppelltvrepair.com .
Aug 25, 2012 | Sony BRAVIA KDL-40V3000 Television
My son just hit his rattle into the screen of my flat panel tv. when turned off it looks fine but when its on you can barely see the picture in the top right hand corner but the spot that he hit it it...
Ur tv have a broken LCD screen panel.Not worth fixing,because the LCD screen panels are limited produced,will cost the same as a new tv,if replaced.Only can buy the LCD screen panels from the tv corporations.Sorry,worth as a whole tv any more.Now ur tv,only worth as salvage for eclectronic boards.
Aug 15, 2010 | Televison & Video
Image on top half of screen is gone. It seems to
The LCD inside the projection unit is broken - nothing you can do about it - it needs replacing.
They are built in two halves to give you higher resolution and quick image response. One is working, the other is broken. You will need to get it serviced.
Aug 20, 2009 | Televison & Video
Dropped itouch now half of screen is gray everything else works fine just can't see half the screen
It's most likely a broken LCD. You can use a ipod repair guide that will show you how to replace the screen step by step, or you can go to the ipod repair nyc.
Jul 20, 2009 | Apple iPod touch
Lap top screen problem
hi
your lcd screen was damged, this is seams to be a manufacture defect so call the manufacturer and ask him to replace if it is warrenty or otherwise throw it away, here after that is like a broken glass
Mar 19, 2008 | Computers & Internet
Broken screen
Sounds like the LCD. Setting anything next to it, bumping it may crack the screen
Oct 20, 2007 | Olympus FE-190 Digital Camera
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Gateway MX6453 Notebook Logo
108 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
