I took the top off my coffee maker to clean the hard-water scum inside the reservoir and underneath, and found the black washer was ripped. I'm having a hard time finding a replacement. Since I'm not sure that just any washer will work (considering the heat and water), I don't want to put one from around the house in it. I can, and have, been sent the replacement kit to fix the leak concerning the recall of some Bunn coffee makers; but this black silicone/rubber washer isn't included with the kit. Does anyone know what I'm talking about and how I can find that particular washer?
Yes, you can get a washer from your local Bunn repair shop. For a list of repair facilities in your area, go to www.bunn.com And yes, the heat is a problem, so you can't use just any washer.
leaking out of bottom. i cleaned it using the de-liming tool today, now when i put water in it and...
(More)
leaking out of bottom. i cleaned it using the de-liming tool today, now when i put water in it and close the lid, water leaks out of bottom. Any suggestions?
I'm helping a friend fix heater problem with the Bunn Model BT10-B. I've taken it apart. Surprised...
(More)
I'm helping a friend fix heater problem with the Bunn Model BT10-B. I've taken it apart. Surprised to see there is no lift tube with check valve for the hot water. Only see a small silicone connector at end of the short copper tube stub under the the top plate. How can the water get from the reservoir to the coffee filter without a long dip tube?
I have a bt10-b.A few weeks ago along with coffee it put out a nasty brown liquid that I could not...
(More)
I have a bt10-b.A few weeks ago along with coffee it put out a nasty brown liquid that I could not figure out.I contacted you and was instructed that it required cleaning.You sent me the cleaning tool and I proceeded to clean the maker.I have now discovered that the unit will not get hot anymore.I now believe that the heating element is the culprit.Is it possible to replace the heating elelment and if so what is the cost. Sincerely Gary Reaves ccbuilders@atmc.net
