Question about Kyocera Mita KM-5035 Printer
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
  • 66 Answers
If you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Posted on Mar 10, 2009
  • 2,120 Answers
Swap the top paper tray with the bottom one.
Posted on Jan 24, 2009
Kyocera km 5035 error c2500
Paper feed motor problem.
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
Not recongnizing bottom tray
the bottom tray sensor may be damaged or dust must be occupied over the sensor clean it
Jan 13, 2011 | Kyocera Copystar CS-5035 Copier
I am just trying to find the driver for a Copystart CS-5035. I cannot find anything on the Kyocera web site. go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Aug 03, 2010 | Kyocera Copystar CS-5035 Copier
I was told i needed a fax module to be able to fax from this copier where would i be able to get this and how would i install it
You need the fax card in order to use the machine as fax unit too. let me know if you still looking for that, so i can send you the manual to setup it.
Feb 25, 2010 | Kyocera Copystar CS-5035 Copier
Touch screen on kyocera 5035 isnt working
Look for a stuck key on the operation panel. Usually is the least used key, a grain of salt will do it!
Jan 27, 2009 | Kyocera Copystar CS-5035 Copier
Copystar 5035 - drawer 2 - we had not been using drawer 2; tried to load it with 8.5x14 paper, however, now that we are trying to use the drawer, we are getting an error message "paper drawer is out of...
You have to reset the drawer by; 10871087 and run SIM 906
You should be able to just key in the Code you wish, then hit the print key to activate.
Then use the touch screen to reset then print key again.
Jan 26, 2009 | Kyocera Copystar CS-5035 Copier
Kyocera Mita KM-5035 Printer Logo
325 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
