Question about Vizio E701i-A3
After one month my VizioE701i-A3 picture appears pink for a few seconds , then the screen is all pink, no picture then the screen goes black
The picture starts pink, then pink screen, no picture then black. TV is on, sound through the home theater is on, no picture.
  • 3 Answers
SOURCE: TV Will Not Start Occasionally
I was having same problem, then on 4/4/08 it went out with just a blue screen, with no signal, then it would turn itself off in about 4 seconds! Not to happy here! its 3 months out of warranty so no help from vizio. my buddy had the same problem a month or so ago with same tv GV42L HDTV. if your handy you could do it yourself, like i will when part gets in. saving some money! its the main board ***'y you can look it up at vancebaldwin or shopjimmy.com. i would just keep using until the screen goes blue. Hope this helps
Posted on Apr 05, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
i have a 50 in vizio and the sound just went out. the picture still works but no sound anyone have any ideas on how much to repair it?
Posted on Oct 11, 2009
  • 19 Answers
SOURCE: Vizio VO420E 42 in. LCD TV
the problem its the main board of the tv not the power supply board.the main one controls all your imputs tv av component etc the cheapest place to find it its at www.shopjimmy.com cheaper than the manufacturer and those dudes that you find online that charge an arm and a leg just to come and just repair your old main board mine as well buy a new one at this site for less ok and you are welcome
Posted on Apr 13, 2010
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Posted on Dec 15, 2010
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Polaroid LCD on Digital Picture frame goes black during power-on
likely the old one had a bad inverter or a back light problem.
Jul 12, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Pink lines only down the middle of the screen aprox. 12" wide for spit second.
Most likely will get worse as you are describing a failing control bd. The part # is 6871QCH038A and is a fairly complicated repair. A good deal of disassembly required, and I would take advantage of your service agreement.
Apr 13, 2008 | LG 50PX1D 50 in. Plasma Television
Sound no picture
Hi there!
If the set is a few months old, it should still be under guarantee. Return to seller for repairs. You will need proof of purchase and purchase date. Good Luck, JUS004
Mar 20, 2008 | Audiovox AVT1498 TV
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Jetway 15" m onitor
check your wire connectors if they are not messed up, or it might be something internal i believe you should return it where you bought it
Apr 11, 2007 | Jetway M1531S 15" Flat Panel LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Vizio E701i-A3 Logo
27 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
