Question about Weaver Optics
Weaver .22 tip-off scope
Owners manual
  • 5 Answers
SOURCE: I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Posted on Apr 17, 2009
miket756
  • 2702 Answers
SOURCE: i have a weaver k-8 scope with adj. rings on front bezel ??????
the front ring is for adjusting point of impact at a given range,,,its called a "parallax ajustment" it corrects for the scopes inaccuracies over its full range say from 10 yds to 100 yds there a bit of a pain on a hunting rifle as you need to focus them every time and that slows down your shooting, when only a snap shot will get the kill you cant wate to mess about focusing the darm scope so i never use them on my rifles,,unless im target shooing,, or im snipping when i have time to take my shot,,,
(a head shot only!) only a parallax scope is spot on aim from 10yds to infinity
Posted on Nov 18, 2009
Testimonial: "waiting for your response on the weaver k8"
agent91
  • 2100 Answers
SOURCE: i am trying to find extra magazines for my
Gunparts.com has the mags, the scope parts, I don't know, you would have better luck finding an old scope for the parts.
Posted on Feb 13, 2010
  • 243 Answers
SOURCE: How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Posted on May 31, 2010
miket756
  • 2702 Answers
SOURCE: directions for mounting weaver 1inch
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Posted on Nov 28, 2010
I have lost the caps that cover windage∧ elevation dials on my k4 scope , can you help me out
Put "Weaver scope caps" in the search box at eBay. You should find some listed. Also, Iron Sight Inc. repairs Weaver scopes, you might try them.
Dec 19, 2014 | Weaver Hunting Gear Polar Caps Size G...
Directions for mounting weaver 1inch see thur scope mounts
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
I am trying to find extra magazines for my mossberg .22 magnum rifle bolt action, also am wondering how hard it is going to be to find parts for a weaver scope....????
Feb 13, 2010 | Weaver Optics
Ruger 22 pistol, Serial number 20476. Year made and value?
For the information you require you will need to take it to a gunsmith, or contact Ruger themselves.
http://www.ruger.com/index.html?r=firearms
Feb 03, 2010 | Weaver Ruger Mini 14 Rifle Elevated Scope...
I am rebuilding a Winchester Model 68 22 caliber and am looking for a manual or exploded view on line. It came in pieces but all seems to be in order.
Gunparts.com ,, They have exploded views of every rifle in their shop. Some rifles, they don't have parts for, they won't have a picture of.
Jan 16, 2010 | Weaver Optics
The dovetail groves are closer on a pellet gun rifle and they ca not close enought.
You probably have rings designed for a standard Weaver style scope base.... you need "3/8" groove .22 style" rings... available from your local gun shop.
Hope this helps, Mark the Gunsmith
Please give feedback!
Jan 08, 2010 | Weaver 1" Inch Steel Gun Rifle Scope...
Instruction manual for 1970's custom .22 scope with BDC
Hold the outer portion of the elevation knob and unscrew the screw on top. then pull up on the outer portion and you'll see a silver screw marked with an arrow and the word "Up". Sight the rifle at a known distance and then line up the knob with that distance as you push it down on the scope and replace the screw. I have one of these and figured this out on my own, however I'm missing the mount and would like some pictures and dimensions of the mount if any of you can get some. I'm gonna be machining a new one and would like to keep it as close to the original as possible.
Sep 08, 2008 | Optics
Optics Logo
103 people viewed this question
Top Weaver Optics Experts
Mark Campeau
Level 1 Expert
freebyrd04
Level 1 Expert
colinat108
Are you a Weaver Optic Expert? Answer questions, earn points and help others
