Question about Vizio E322ar
My VIZIO e322ar will turn on and have sound but no picture.
The backlight is though. it won't change channels or volume only turn on and off. What is the problem??
phongnv
  • 56 Answers
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
dsacco86
  • 1077 Answers
SOURCE: i have a vizio p42 hdtv 10A, and it turn on, but
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 04, 2009
  • 13 Answers
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
SOURCE: no sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Posted on May 01, 2010
ladywinn
  • 5138 Answers
SOURCE: Hi, I'm getting sound and no picture. I can
I read alittle about your problem and the T-Con Board is located in the Middle up on Top of other Boards It controls the color/ Video on TV,Since you hve No Picture? ,When you said you replaced Main Board was it the Signal Board? Shopjimmy.com has a few boards .
Encompass Parts Distribution List this Model/Parts 1-800-638-3328
Posted on Dec 13, 2010
Hi, I have a Vizio 32" smart t.v. Model # E322AR and it doesn't work. It won't turn on anymore.
U have a sick puppy there. U might want to check the power supply of unit since it is usually one of the primary areas that go on these products.
Aug 19, 2015 | Vizio Televison & Video
Viso light and picture backlight comes on wont turn off
UNPLUG AND WAIT 10 MINUTES OR LONGER THEN TRY
Jun 11, 2014 | Vizio E322ar
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
My sanyo remote model DS27510 won't turn my tv on or off
do you mean you can use only the remote in channel and volume settings but can not use to turn off the tv. ok the problem is just only the power button for the remote. what you need is to clean the rubber contact inside using with an eraser. to do just unclip the lock of the remote controller to remove the housing and to access the internal part.
Jul 21, 2012 | Televison & Video
Hitachi lcd led tv won't turn on.
Without more info or seeing the set, the most likely problems are :- the inverter that powers the backlight has failed or the backlight itself has failed The first is the cheapest and easiest to repair the latter could mean the screen needs to be replaced. You don't say if you are getting sound though. if you aren't it may just be that the internal fuse has blown. I hope this points you in the right direction.
May 29, 2012 | Televison & Video
Vizio E322ar Logo
919 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
