Question about Sony Handycam CCD-TR87 Camcorder
Fuzzy picture sony 8mm camcorder,cleaned head, still fuzzy picture.is there only one head.ccd-tr5
The tape is not adjusted to cylinder head. Both the sound and picture is lost when the tape is not exact on the wheel (head). If the camera has not been used for a long time then can the adjustable pins start to rotate and change the position of the tape when it is used again. The oil has dried out and the pin is not running smoothly, and the screw starts to rotate as well.
So, the solution.
a) remove the plastic cover so you can see the two pins that pulls out the tape from the cassette.
b ) small droop of oil on the top of the two pins
c ) use a small screwdriver to change positions of the tape, by turning screw on the top of the pins.
Put in the tape again and test , thus you have to do small adjustments. Repeat the test until you see the picture.
This is simple but it will take some time. I have now saved all old films, it is hard to find a old video-8 analog camera ....
/U
Posted on Jan 30, 2009
When i try to record a yellow arrow then a message saying need head cleaner but sony doesnt make that model head cleaner what do i do
Greetings Jerry - You don't need a Sony head cleaning tape. 8mm is a standard that was used by many manufacturers.
Head cleaning cassettes for 8 mm and Hi8 are exactly the same, there is no Hi8 head cleaning cassette except one that Sony used to sell for almost three times as much as a regular 8mm and offered nothing special.
Sony also made a bit of a big deal that you can't use "wet" cleaners inside your Sony Hi8 camcorders...also not true and Sony was just trying to part you from your wallet.
I can understand if you have some concerns about these things so I suggest you Google around something like "head cleaners for 8mm and Hi8."
Good Luck,
Mikeywaf
May 12, 2011 | Sony Hi8 CCD-TRV138 Camcorder
I Can not see picture and also hear the sound when i play back my recorded ...
try running a head cleaning tape for about 5 to 10 seconds and then try to play your tape again. If it improves, but is not yet right, repeat process. We use a Sony 8mm Head Cleaner in our repair shop (for minor cleaning issues) and it works great....lasts a really long time too.
Hope this helps you
www.austintelstarservices.com
Oct 03, 2010 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Does sony ccdtrv12 camers use normal 8mm or hi8mm
CCD-TRV12 needs standard 8MM tape, it is not Hi-8 camcorder.
Thanks.
Mar 03, 2010 | Sony Handycam CCD-TRV12 Camcorder
The picture on the video when I do playback get's fuzzy n snowy sometimes and other times the camcorder will eject the tape without me asking to, sometimes during recording.
You have two problem, Heads need to be cleaned or there are bad capacitors in the video line from the heads. Also your eject switch is bad or you may get lucky and be able to clean it with contact cleaner. The vtr and cam switches may be going out also . I have had to change all three before.
Jul 04, 2009 | Sony Handycam CCD-TR517 Camcorder
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
How to clean heads
Hi Jayne,
Yes there are commercially available head cleaners for 8mm camcorders. I'm pretty sure you can find them at Radio Shack or Best Buy...or if you google it, you can find a million of them online. Here is a picture of one:
http://ecx.images-amazon.com/images/I/51PXF9PGB1L._SL500_AA280
Rob
Mar 11, 2009 | Sony Handycam CCD-TRV15 Camcorder
Play back fuzzy
It looks like dirty video heads. Put brand new tape on camera and play it all the way to the end several times if necessary. It will clean the video heads. Good luck!
Nov 24, 2008 | Sony Handycam CCD-TR517 Camcorder
Fuzzy movies
The Image sensing IC called CCD may be defective.
We can supply this.
The images may be fuzzy with random colors and noises of varying degree and at times Ok.also.
Jan 13, 2008 | Sony Handycam CCD-TRV12 Camcorder
Fuzzy unclear movie
This can be a defective CCD which senses the images.
Random moving lines and color patches are the symptoms.
We can provide this in 3 to 4 weeks from Sony.
Oct 28, 2007 | Sony Handycam CCD-TRV12 Camcorder
Sony Handycam CCD-TR87  Camcorder Logo
241 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
