Question about Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature
WHAT IS THE HEIGHT WIDTH AND DIMENSIONS OF THE MAYTAG ELECTRIC WALL OVEN MODEL cwe9000BCE
VtToolMan
  • 704 Answers
SOURCE: I need to know which kind of plug is used on this
Hi, Most wall ovens are hard wired to a 30/40/50 Amp 220V-AC circuit. Please refer to the installation instructions that are provided with the unit for all the specs and dimensional details for installing the wiring junction box.
The best thing you can do is to provide an extra 5-6' of the appropriate sized gauge wire at the oven location, so the installing electrician can have enough to properly connect and locate the junction box or directly connect to the wall oven's built in junction box.
If you don't have the installation instructions, please contact Maytag at the following link to obtain a free installation guide for your particular oven.
http://www.maytag.com/support/manuals_literature.jsp
You can also contact them by phone, as your model appears to be an older model, from what I could determine with the partial model number.
Maytag customer support can be reached by calling them toll free at 1-866-616-2601
Hope you find this Very Helpful and best regards!
Posted on Dec 01, 2009
  • 523 Answers
SOURCE: Bottom electric heat element in wall over does not work
replace control
Posted on May 27, 2010
taran_2005
  • 10515 Answers
SOURCE: display flashes f1 on my
An F1 is typically a shorted transistor in the electronic control, but can also be a touchpad failure or a sensor short.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    1. NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 10, 2010
SOURCE: Maytag electric oven model cwe5800acb.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Posted on Apr 30, 2011
mc1bean
  • 3053 Answers
SOURCE: I need a diagram for double wall electric Maytag
Hello, jenny
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from
repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
Whirlpool double wall oven RBD306PD26 size specifications
From what I could get from the service manual, the oven is a standard 30 inch width. The best thing to do is get a yard stick and measure length, width, and height. Take pix with a phone so you have references to show a salesperson or a tradesman if you are buying new or having upgrades done.
Sep 02, 2015 | Whirlpool Ovens
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
We just bought a Kenmore Elite Oven, model 4809, at a Sears Outlet Store. I've looked all over your website and cannot find dimensions or installation instructions. I looked at the online manual for the...
I just purchased the same model and have been searching on-line for the exact same information. Not sure if you still need it but the Sears Outlet website lists the opening dimensions for the Kenmore Elite Oven 4809 as Width 28-1/2 in. min., 29 in. max. Depth 23-1/2 in. Height 29-1/16 in.
May 01, 2011 | Kenmore Ovens
I want to know its height, width, and depth in feet or inches
The dimensions are 28.3" x 23.3" x 21.7" (using the 1" = 25.4 mm conversion and rounding as appropriate). It is a little larger on the first two dimensions and smaller on the third.
I hope this helps.
(You can see the value without rounding to significant figures here: http://www.onlineconversion.com/length_common.htm )
Jul 13, 2010 | Zanussi ZHQ575 Electric Double Oven
Need deminsions to purchase new oven
every oven has different dimensions, the easiest and best thing to do, is to slightly pull unit from the cabinet its installed in and measure the max. opening both height and width.--- if its a freestanding range that you are talkin about the dimensions are standard inches,, 20-24-30-36.
Dec 15, 2008 | Ovens
Installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Oct 23, 2007 | Whirlpool RBS305PDS Electric Single Oven
Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature Logo
53 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
