Question about Samsung PN42C430 42 in Plasma TV
Broken digital optical cable connector on my samsung tv, can I get a replacement piece and where?
The port where my optical cable plugs into my tv is broken and now the cable won't stay connected. I am hoping to be able to find a replacement part.
SOURCE: samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Posted on Mar 06, 2009
SOURCE: Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Posted on Apr 25, 2009
bomark2002
  • 160 Answers
SOURCE: I have Samsung A550 46 LCD HDTV, and Anteina IN Broken
Yes it can be fixed if the tuner board was not damaged. Get an RF modulator, you can pick them up at walmart, and use your RCA inputs in the back. All you do is input your main tv cable into the RF mod cable in, then connect to the out of it with your RCA cables and then into the RCA connect in, into the back of your tv. Or, like you said, you can input your main tv cable into your vcr/dvd then come out of that with the RCA cables, and again into the RCA cable in on your tv. This way you have to syncronize your channels after you do this to get the picture. You know, vcr on channel 3 while your tv is set to input 1 or whatever needs to be done.
Posted on Jul 07, 2009
  • 1632 Answers
SOURCE: We are trying to use our Samsun HDTV 1080P as a PC monitor
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
SOURCE: samsung LED UE46B7020 tv wont play sound through my HT-C5500
press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
Posted on Jun 30, 2010
I want to connect my DVD and TV to my Samsung Sound Bar but there is only 1 optic cable port on the sound bar
You can use the other inputs as long as they are labeled a/v or left, right , video. or are coaxial cable. optical means it is digital light input , not optical {video}.. the optical is actually a piece of monofilament that a light signal passes thru.
May 13, 2017 | Samsung Televison & Video
How do i connect a technika TKSBSE213 soundbar to a telly
Does your TV have a Digital optical port? It's a cable that sends a red light source. That is actually how you're suppose to hook up a soundbar. digital optical cable Bing images Straight forward. Plug and play. If you're TV doesn't have an optical port, as I know your soundbar does then you have to use a stereo Y Cable. 3.5mm to Red/White. Sound bar will have 33% the power going this way as opposed to an optical cable. Aux Audio Out has a itty bitty amp pushing power. Purpose of the Digital optical Cable is a light source.
Jan 18, 2015 | Audio Players & Recorders
How to plug my external speakers to my viera tv
This television only outputs digital audio called PCM / Dolby Digital, Fiber Optic so you may need an amplifier that has a digital in port (if the speakers are rca red and white cable plugs then the amplifier needs rca output ports). Then you would need to connect the amplifier to the speakers
. Unless the speakers have a digital in port which I am unsure on ,. The digital out audio port on your tv uses a fibre optic digital audio cable..
page 13 of the user manual shows this digital output port.
http://service.us.panasonic.com/OPERMANPDF/TCL42E50.PDF
Oct 28, 2014 | Panasonic Smart Viera E50 Series Tc-l47e50...
My soniq LCD TV has no audio out ports it has
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereophono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds sterling
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 10, 2014 | Televison & Video
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
Do I have an optical pug for my fusion 37 in tv as an option
Look where all the connectors are located on the tv to see if there is a place marked "Digital Audio Output" If there is then remove the rubber port cover and plug in the optical cable. If there is no digital output, then you cannot use that feature on the Bose
Jan 02, 2014 | Fusion Fus37 dvd 37 LCD TV
Connect samsung wireless airtrack model hw-fm45c to samsung tv model fvm3982
Optical out ports on TV's have a rubber plug covering the port to prevent dust from entering when it's unused. Look again at the tv for that rubber plug. It may be there.
Dec 31, 2013 | Televison & Video
No "red light" on Digital In
The port on the jvc is probably an input, which does not produce light. Only optical outputs will have the red light in them.
Jan 04, 2013 | JVC TH-A75R System
JVC TH-C60 DBS stopped working
When you say the "TV side" you really mean the Cable or Satellite Box audio, right? There's no digital optical connection intended for the physical TV.
I hope you're not really looking directly into the cable with your naked eye. A safer way to visually check for the presence of red laser is to hold a thin piece of white paper up against the cable and observe the spot.
With your remaining good eye, look INdirectly or hold a thin piece of white paper in front of the the optical port on the JVC to see if there is a visible red glow. Most likely the cable itself is the problem. Make sure it has large open loops rather than tight bends throughout its routing.
Mar 24, 2010 | JVC TH-C60 System
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung PN42C430 42 in Plasma TV Logo
290 people viewed this question
Henry  Thomas
Henry Thomas
