Question about Whirlpool 18 in. ADP530 Free-standing Dishwasher
Whirlpool ADP4504- power cut when turned on!!!
When the dishwasher is turned on it tripps all the electrics in the house (plugs only)Bit confused and its ran out of its warranty now so if anyone has any ideas id be gratefull. many thanks kerri.(ps i have checked the fuse and replaced the plug.)
  • kerri grice Jul 11, 2007
    hi theres no burning smell (too be honest no time to burn anything just instantly tripps) How do i get to the motor and how will i know if it needs replacing? i know its a lot of questions but am quite handy when i know what i doing ie)repair manual but dont seem to be able to find one.Thanks for your help so far.
  • Whirlpool Master
  • 909 Answers
Very possible its your element.  has a fault down to earth.  more chance of that than your motor.   suggest you take off one both element wires and retry running washer.  no tripping means element problem.
Posted on Oct 21, 2007
  • 72 Answers
Could be that the motor is locked up (mechanically binding and wont turn) causing it to draw a lot of current, i.e. more amps than your breaker is sized for. is there any burning electrical smell?
Posted on Jul 11, 2007
Whirlpool 665-13442K901 dishwasher electrical plug in shorts out
You reversed the black and white wires on what? Don't ever do that. One is the line and one is common. They are polarized for a reason.
Immediately stop using that outlet before you burn your house down. Switch the breaker off to that power circuit, then have a qualified electrician check it out.
Jan 28, 2018 | Whirlpool 24 in. Built-In Dishwasher w/...
Hi, the Council shut the water off to our house then when the water was turned back on I put the Whirlpool dishwasher on and now every time I try to use the dishwasher it cuts the power to the house. Will...
Hello - Probably, but someone with basic electrical skills can check the wires in the power connection box under the unit. If these wires look good, the problem is best left to a pro. Some part of the circuit is grounding, causing breaker to trip. Finding out where is an on-site job. Let me know if this info helps- have more if needed. -Thanks- Ed
Mar 11, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL BUT DOES NOT START NOR DOES ANYTHING TURN ON. LAST YEAR HAD THE SAME PROBLEM TECH TOOK FRONT APPART AND THE DISHWASHER STARTED WORKING. I...
Check you electrical power box that feeds to the house. If this dishwasher is hooked up under a sink counter and there is a garbage disposal in the sink area the dishwasher should be hooked up to the same circuit that the dishwasher is hooked to. If the garbage disposal works then the circuit is good your problem is either in the connection from the plug to the dishwasher or in the timer section of the unit. Either way the unit wont operate. Check power into the unit then check power at the hookup from the dishwasher to the plug itself if all is good then timer has gone bad
Good luck hope this helped you some
Dave
Jan 28, 2010 | Whirlpool DU943PWK - Multiple Color...
Dishwasher does not turn on. it is plugged in but
These are just some possible solutions that are worded for general assistance, I'm sure you have checked many of these things but others may not have;
The circuit breaker in the electrical panel may need to be reset. Hopefully it is labeled and will be easy to find without cycling power to everything else in the house.
The dishwasher may be on a GFI (ground fault interruption) circuit. The outlet may have a reset button on it that needs to be pushed or the circuit breaker in the electrical panel may have a built in GFI that needs to be reset.
Many dishwashers are installed with a light switch in the vicinity of the unit that is used as a disconnect. The light switch will cut power to the dishwasher if turner off. The switch is sometimes above the counter and sometimes below the sink.
There is also the possibility of a faulty On/Off button or dishwasher circuit board.
Dec 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Electricity in house cut off. Now, printer does
Make sure power adapter is plugged into a power outlet that you know works. Then try and power drain the printer by unplugging the power cable and letting it sit for a bit and pressing the power button a few times. Then plug the power back in and see if it power up. If not, then the power adapter itself or the internet power on the printer might be faulty.
Mar 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
How do i reset my dishwasher adp4504 . i have kept my finger on the start button but just keeps on flashing
Hi!
Try pressing sani rinse and heated dry back and forth. All the lights will light and it will reset itself.
Please see this link for more information---
Whirlpool dishwasher reset
Please rate the solution if found useful.
Thanks
Rylee
Feb 24, 2009 | Whirlpool 18 in. ADP530 Free-standing...
Whirlpool aop 4150 1 5
Check to see if there are corroded connections to the electrical feed from breaker to the machine.  Could be anywhere along the way.
Nov 06, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool 18 in. ADP530 Free-standing Dishwasher Logo
152 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
