Question about Epson CX4200 All-In-One PSC Printer
My Epson cx 4200 won't print because each attempt the paper jam light flashes and the printer stops trying to print. The paper is being pulled into the machine un-evenly.
  • fishshirts Jan 27, 2009
    There are no foreign objects in the printer. I almost wish there was!
    The paper will not feed into the machine and it is out of warranty.
    I guess the rollers are out of alignment and while I may take the machine apart I doubt I will be able to fix it. Thanks for your help.
  • Epson Master
  • 419 Answers
It's highly likely that you either have a foreign object down the paper feed tray or the guides are incorrectly set...
Hopefully one of these will solve this:
1. Remove any paper, tape down the scanner lid and
gently tip your printer upside down and give it a GENTLE shake to see if anything drops out. This is really only something I'd recommend for someone strong and careful so take your time.
2. Check for any jammed foreign objects such as pens, paper clips, etc...that have fallen down into the printer. The place to look is wherever the paper seems to be bunching up most as it goes through
3. Make sure you're inserting the paper, with the guides set to the correct width and not loose. The guides help correct any issues with skew as the paper is pulled in, so this may correct any other issues.
Hope one of these helps..
Posted on Jan 24, 2009
Hello. My Epson Stylus CX 4200 now flashes the letter E and all the lights flash, including "error." How do I get it working again?
here's what you can do:-disconnect the printer from the computer-turn off the printer-inspect for anything foreign inside like jammed paper-turn the power back on-remove the ink cartridge-check the chip connnector at ink tank and at head carriage. If its dirty clean it with soft moist cloth. -check the status monitor. which ink tank not recognized. -press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
if that doesn't work, replace ink cartridge ONLY if you have a spare. DO NOT BUY new ink as the printer is bound for repair.
Nov 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  1. Turn off the Stylus CX.
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
202 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
