Question about Linksys Wireless-G WUSB54G 802.11g/b
Computer shuts off/reboots when Linksys is plugged in via UBScord
Everytime I turn on computer then plug in wireless adapter it shuts down computer and prompts computer to reboot.
  • cassjenkins Jan 24, 2009
    Interesting and thankful but its the original driver that came with adapter. what are you suggestions? I reformatted computer w/a company because it was doing it before and still doing it now. At store it works w/adapter her at home it still does same thing. Turns off and reboots once you plug in adapter via UBS cord?
  • 871 Answers
You may be using the wrong driver for the wireless adapter youre using. pls check or update the driver for your wireless adapter. it is niormal for the computer to reboot after initial installation of the drivers but with your case, you may be using the wrong drivers because the computer reboots whenever you plug it in.
Posted on Jan 24, 2009
M50vc recover wireless
If the problem is with the computer, in the Tray Notification Area, right click on wireless icon and open Network Sharing Center, click on Change Adapter Settings, Is the wireless adapter enabled? In Device Manager, Network Adapters, Is the wireless enabled? Reboot the computer and the wireless access point by removing power and battery and plug in wireless, let it run the selftest, plug in computer and boot normally. You can always Reset the wireless access point to default settings
Nov 30, 2012 | ASUS M50VC-AP012C Notebook
My LINKSYS as for password, it is locked
Press and hold the reset button of the Linksys router using a pointed object (like a paper clip or pen) for 30 seconds.
The reset button is located in the back of the Linksys router closest to an Ethernet port.
The button is recessed to protect you from accidentally resetting the modem.
Unplug the Linksys router while pressing the reset button.
Shut down your computer for one minute.
Plug the Linksys router back into the wall outlet.
Reboot your computer.
Open your web browser to access a website.
Type the below in the address bar if you want to reset your password:
http://192.168.1.1
A prompt from the site will request a user name and password.
The user name stays blank, or, in some models, is "admin".
Navigate to the security tab. Input your new password to protect unauthorized access to your router
hope this helps
Sep 17, 2012 | Linksys E3000-rm 802.11a/b/g/n 2.4/5ghz...
My LINKSYS ask for password, it is locked
http://192.168.1.1
hope this helps
I had put my desktop in storage for a year. Before storage it worked fine, with the wireless adapter. When I start up the computer, everything works fine. When I plug in the wireless adapter via a usb...
try different usb ports.
trying something else with a usb connection, if it restarts will all of the above then its a dodgy usb connection which has weaken during the hibernation period. and will need looking by a techy.
if the above dont do anything then it could be the adapter
Oct 15, 2010 | Linksys Wireless-G WUSB54G 802.11g/b
Plugging device into USB makes computer restart
I had just scrubbed the hard drive and reloaded the operating system and I could not install the linksys because the machind rebooted everytime I plugged in the usb connection. I noticed a box coming up that was trying to dial up an internet connection. I went into the windows internet setup and checked the box that say "never dial a connection". This seems to have fixed the problem.
Dec 26, 2009 | Linksys Computers & Internet
No connections with my wireless on asus g72
It is a hardware problem. The switch on the Asus G72GX is at fault. I own the same machine, and the switch will hard-lock the wifi and will not unlock it. The hot-key will not work either. It took me a very long time to get to the root of the problem. The only solution appears to be to switch the wifi off, power down (restarting didn't work for me), turn the switch on and then power up.
Dec 12, 2009 | ASUS Computers & Internet
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Problem with installaion of WUSB54G Adaper. computer keeps reboot
Normally this means that its either an IRQ or basically conflicting with another device. or there is something wrong with your USB ports. Can you try antoher port on the computer?
Feb 06, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
I have a linksys wireless adapter WUSB54GC on a Toshiba satellite laptop, I have downloaded the driver for it, try updating the XP driver to the location it is, but the computer does not update the driver....
Unplug the USB Linksys. Open device driver and uninstall the Linksys network device. Go to add/remove programs and remove the Linksys utility. Reboot. Now run the .exe you downloaded from Linksys. Then, and only then, plug in the USB.
Jan 01, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys Wireless-G WUSB54G 802.11g/b Logo
271 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
