Question about GE Monogram Side by Side Refrigerator
ZIS420DMB ice dispenser flap won't close - GE Monogram Side by Side Refrigerator
HVACRH20
  • 237 Answers
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Posted on Jan 08, 2007
catriver
  • 878 Answers
SOURCE: Ice maker
Smitty, if this is a GSS20, General Electric model you have an electronic model ice-maker. There is no water adjustment screw. Here's how the fill works; when the harvest is finished the icemaker will enter the fill cycle. The amount of water entering the mold is controlled by temperature. Before any water enters the mold has to be at least 35.6 degrees. Water entering the mold will cause the mold temperature to change, effecting the resistance of a thermistor. The first fill activates the water valve for 5 seconds. The thermistor checks the temp of the mold. If the temperature of the mold exceeds 39 degrees the icemaker will end the fill cycle and enter the freeze cycle. If the temp of the mold is still below 39 degrees, the control will assume that an insufficient amount of water entered the mold, and energize the water valve for another 2.5 seconds. Now it will check the temp again. If the mold is still below 39 degrees a third fill of 2.5 seconds will occur. You could have a thermistor that's out of spec. Usually on this model, the power LED on the icemaker will flash 1/2 second on and 1/2 second off if the thermistor is open or shorted. You could have a water valve that is not seating properly and allowing more water to enter the ice-maker. You can run a cycle on this ice maker by turning it off, then on again and pushing the feeler arm in 3 times within 15 seconds. Watch how the fill works. Anyway, outside of the excellent information posted by 24 seven, This will give you an idea of how the icemaker works. Catriver.
Posted on Jun 01, 2007
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
  • 1122 Answers
SOURCE: Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Posted on Apr 14, 2009
aasc
  • 1606 Answers
SOURCE: GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Posted on Jul 11, 2009
THE ICE DISPENSER FLAP IS NOT CLOSING ALL THE WAY
There is a solenoid that operates the flap, although there are many other components that could be broke but usually its the solenoid
Jul 22, 2015 | Frost Refrigerators
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
The flap on the ice maker dispenser will not close.
Problem with these flaps are that they have plastic hinge which work great for sometime when they are new and have shiny inner surface but with use they develop minor scratches which cause resistance and hence partial closing. Either get the flap replaced or apply Vaseline jelly in the moving part of the hinge.
Apr 23, 2013 | Refrigerators
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Freezer door ice dispenser flap will not close completely. The cold air is leaking out of the freezer. What can I do to fix?
There are multiple parts to the dispenser for GE. You say that door isn't closing properly, which could mean that the solenoid isn't working properly, or that the door flap retainer itself is broken, I want to say that they make a complete kit for it but not for certain,
Jun 02, 2012 | GE Refrigerators
Flap for ice dispenser won't close
ok you have to replaced the flapper (door recess asm) here is the part no. WR17X3093 makle sure to defrost all ice or snow around the flapper and replace it with the new one
Aug 04, 2011 | Hotpoint HSS25GFP Side by Side...
LG LSC27931st.ice dispenser flap doesnt close after ice drops
Not that this is much help, but I have the same problem with the same model.
Dec 02, 2009 | LG LSC27931S Side by Side Refrigerator
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
GE Monogram Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
