Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
Keeps turning off
I keep loosing internet service every couple min. the light will be green, then it will flash then it turns red, then it turns green again...........I The modem is a Netopia. Silver box i dont know what it is
  • jckeebz Jan 24, 2009
    Without this Working my phone also does not work PLEASE HELP
mortega
  • 43 Answers
SOURCE: Internet light is red
If you haven't done so already I would turn the netopia router off and back on again at least once. If that doesn't solve the problem it's probably a sync issue with your providers equipment. I'm assuming you're using ATT because of the Netopia router, but generally speaking you should contact your provider and have them run a line test.
They can determine if the line is good or not. If It is all working fine at the time you call ask them to run monitoring on the line for the following 24-48 hours to try and anticipate a reoccurrence. Insist that they call you back regardless at the end of the monitoring term to share their results with you.
Hope this helps.
MO
Hope this helps.
Posted on Jul 13, 2008
Jim1969pa3
  • 152 Answers
SOURCE: i loose internet everytime the phone rings
Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
Posted on Apr 06, 2009
spincycleus
  • 62 Answers
SOURCE: netopia router test page keeps poping up while i'm on line
You can try enabling your pop up blocker in internet options, but this is a problem i have never heard of before, and now i see that 3 of my people have it.....hmmmm
The proper method to bring resolution to the issue is to reset the modem. If it keeps doing it, you need to call your ISP and have them swap it out. If its a netopia 3347, those are new, it only came out last year, call your ISP and have them swap it out, there shouldnt even be a charge. 1-877-SBC-DSL5, thats 1-877-722-3755. When you're prompted, say 'tech support' for tier 1.
Posted on May 01, 2009
spincycleus
  • 62 Answers
Reset your netopia by holding the reset button in for at least 30 seconds.
Reconfig your netopia again.
You do this by opening internet explorer. It will say "Page cannnot be displayed"
type 192 168.1 254 in the address bar (where you normally type www)
the username is admin
the password is the serial number on the bottom of the netopia
click on configure
click on quickstart
put in your userID like spincycleus@sbcglobal.net
and your password
click submit at the bottom
and then click the yellow triangle dealie at the top right
click save and restart the database
when it comes back on in a few minutes, you'll be online
If this doesnt resove the issue, then your firmware is messed up and its time to swap out the netopia.
spin
Posted on Jun 22, 2009
SOURCE: I need help configuring my mac airport card to my netopia 3300
Try turn off the router, then back on
Posted on Aug 12, 2009
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Hello, I keep loosing internet connection, how can I tell if there is a problem with the modem?
try to check the status of the lights on your modem. Try to check the light in globe icon, that is the icon for your Internet status, if is GREEN it mean to say that it has connection. When it turns to RED, check the DSL light if it is in SOLID GREEN, When it blinks try to check it with your Service provider.
May 29, 2011 | Zoom X6 (5590) DSL Modem (55900003)
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
Well when I turn on my ps3 the green light turns into a yellow light some people call this the yellow light of death after it goes yellow it turns into a flashing red light I try to repaet it but it keeps...
well yes obviously the flashing red light means that if u do not turn off ur PS3 it will die. but depending on how long u have had ur PS3, it may be becuase the life span is almost over.
if u have not had for a couple years it is most likely a manufacturing error
u should send it in to sony before the warranty is up and have them take a look at it
Jul 25, 2008 | Video Game Consoles & Games
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
TV keeps turning off.
could be a couple of things
first i would guess to be convergance ic then IC831S (STR-X6456).and could be loose connection.
you could try this to narrow it down, purchase a can of freeze at radio shock and spray it on these ic one at a time see if it stays on longer or just replace them
Dec 20, 2007 | Samsung HCN4226W 42" Rear Projection...
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
74 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
