Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Keypad lock will not operate even after changing battery
My schlage keypad will not do anything anymore i even tried new batteries has happened on all three of my locks
Probably need to be reset to factory default. Since it is all your locks you probably change all the batteries same time.
provided link to Schlage
http://www.schlage.com/en/home/contact-us.html
Oct 01, 2016 | Schlage Deadbolt. Century Satin Nickel...
My lagard lock safe won't open-no battery.
If internal battery is depleted and will not allow lock to open, hold a new9-volt alkaline battery on the contact points (large battery terminal to
large keypad contact, small to small) located on the front of the keypad.
Maintain contact, enter and valid code and turn keypad to open lock.
Lock contains a non-volatile
memory, even with batteries removed the lock will retain
all programming.
NOTE: You must maintain battery contact at all times throughout the
entire procedure.
Mar 15, 2014 | Safe International Digital Electronic Safe...
Is the keyless locked affected by condensation? IE - 40c weather?
Well, it's battery operated, and batteries don't do so well in -40 degree temperatures. So, yeah, even with the batteries on the inside, a lot of cold is transferred. The cold doesn't do much for the internal mechanical movement of the lock, either.
Aug 06, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Lock beeps every 10minutes changed batteries still does it
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing. http://www.weiserlock.com/en/SupportPortal/SuggestedFaqs.aspx?prod=FAQ+Categories_Keyless+Entry_Power+Bolt+1000
Dec 25, 2010 | Weiser Lock Powerbolt 1000 Lock
We changed the batteries and the lock will not reset it will not lock or unlock just keeps bepping
Oct 04, 2010 | Weiser Lock Powerbolt 1000 Lock
2000 Lincoln Towncar. Keypad on door will not unlock doors. Interior lights do come on. The last two keys pushed simultaneously will occasionally lock the doors. I am using the code printed on a sticker in...
The driver door module (DDM) is connected on the standard corporate protocol (SCP) communication network. The DDM controls many functions including power windows, power door locks and remote keyless entry. The DDM also communicates with the driver seat module (DSM) to control the power mirror and seat memory functions.
Do you know anything about automotive electronic control modules ?
The driver door module (DDM) receives inputs from the digital transmission range (DTR) sensor, ignition switch, seat switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
Best thing to do would be to have a factory scan tool hooked up to check for DTC'S diagnostic trouble codes . That should be the first step if it's not programming the code.
  • The doors do not lock/unlock using the keyless entry keypad
  • Keypad.
  • Circuitry.
  • Driver door module (DDM).
  • GO to Pinpoint Test L .
PINPOINT TEST L: THE DOORS DO NOT LOCK/UNLOCK USING THE KEYLESS ENTRY KEYPAD CONDITIONS DETAILS/RESULTS/ACTIONS L1 RETRIEVE THE RECORDED RESULTS FROM BOTH CONTINUOUS AND ON DEMAND SELF TESTS Use the recorded DDM DTCs from the Continuous and On Demand self tests.
  • Are any DTCs recorded?
Yes For DTC B1525, GO to L3 .
For all other DDM DTCs, REFER to the DDM Diagnostic Trouble Code (DTC) Index.
No If the door locks are inoperative, GO to L2 .
If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 .
L2 CHECK THE DOOR LOCK OPERATION Check the door lock operation by depressing a door lock switch.
  • Do the door locks operate?
Yes GO to L3 .
No GO to Pinpoint Test E . L3 MONITOR THE DDM PID KEY_PAD
Scan tool
Monitor the DDM PID KEY_PAD.
  • Are any of the keyless entry keypad switch numbers present?
Yes GO to L4 .
No GO to L5 . L4 CHECK THE KEYLESS ENTRY KEYPAD SWITCH
Keyless Entry Keypad Switch C525
Yes If 1/2, REPAIR Circuit 78 (LB/YE). TEST the system for normal operation.
If 3/4, REPAIR Circuit 79 (LG/RD). TEST the system for normal operation.
If 5/6, REPAIR Circuit 121 (YE/BK). TEST the system for normal operation.
If 7/8, REPAIR Circuit 122 (YE). TEST the system for normal operation.
If 9/0, REPAIR Circuit 123 (RD). TEST the system for normal operation.
No INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry . L5 CHECK THE KEYLESS ENTRY KEYPAD INPUT WITH THE KEYLESS ENTRY KEYPAD SWITCH Monitor the DDM PID KEY_PAD, while depressing all the keyless entry keypad switches one at a time.
  • Are all the keyless entry keypad switches operating correctly?
Yes GO to L9 .
No GO to L6 . L6 CHECK CIRCUIT 797 (LG/VT) FOR VOLTAGE
Keyless Entry Keypad C525
Measure the voltage between keyless entry keypad C525-7, Circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, Circuit 797 (LG/VT), and ground.
  • Are the voltages greater than 10 volts?
Yes GO to L7 .
No REPAIR Circuit 797 (LG/VT). TEST the system for normal operation. L7 CHECK THE KEYLESS ENTRY KEYPAD SWITCH INPUT While monitoring the DDM PID KEY_PAD, momentarily connect a fused (7.5A) jumper wire between positive battery post and keyless entry keypad switch C525 as follows:
    Keypad Button Keyless Keypad Switch C525 Circuit 1/2 Pin 3 78 (LB/YE) 3/4 Pin 4 79 (LG/RD) 5/6 Pin 5 121 (YE/BK) 7/8 Pin 6 122 (YE) 9/0 Pin 1 123 (RD)
  • Are all the keyless entry keypad switch inputs operating correctly?
Yes INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry .
No GO to L8 . L8 CHECK THE KEYLESS ENTRY KEYPAD SWITCH CIRCUITRY FOR AN OPEN
DDM
Measure the resistance between keyless entry keypad switch C525 and DDM as follows:
    Keyless Keypad Switch C525 DDM Circuit Pin 3 C521 Pin 8 78 (LB/YE) Pin 4 C521 Pin 13 79 (LG/RD) Pin 5 C521 Pin 16 121 (YE/BK) Pin 6 C520 Pin 24 122 (YE) Pin 1 C520 Pin 25 123 (RD)
  • Is the resistance less than 5 ohms?
Yes INSTALL a new DDM; for additional information, REFER to Section 419-10 . TEST the system for normal operation.
No REPAIR the circuit in question. TEST the system for normal operation. L9 CHECK THE KEYLESS ENTRY KEYPAD BACKLIGHT Depress a key on the keyless entry keypad.
  • Does the keypad illumination operate correctly?
Yes INSTALL a new DDM. For additional information, REFER to Section 419-10 . TEST the system for normal operation.
No If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 . L10 CHECK THE KEYPAD - DDM ACTIVE COMMAND KEYPAD BACKLIGHTING LIGHT ON AND OFF Trigger the DDM active command KEYPAD BACKLIGHTING LIGHT ON and OFF.
  • Does the keypad illumination turn off and on?
No GO to L11 . L11 CHECK DDM GROUND - JUMPER CIRCUIT 66 (LB) TO GROUND
DDM 522
Connect a fused (7.5A) jumper wire between DDM C522-4, circuit 66 (LB), and ground.
  • Does the keypad illuminate?
No GO to L12 . L12 CHECK CIRCUIT 51 (BK/W) FOR OPEN
Measure the voltage between keyless entry keypad C525-7, circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, circuit 797 (LG/VT), and ground.
Yes GO to L13 .
No REPAIR circuit 797 (LG/VT). TEST the system for normal operation. L13 CHECK CIRCUIT 66 (LB) FOR OPEN Measure the resistance between keyless entry keypad C525-2, Circuit 66 (LB), and DDM C522-4, Circuit 66, (LB).
No REPAIR Circuit 66 (LB). TEST the system for normal operation. L14 CHECK THE KEYPAD ILLUMINATION - DDM DISCONNECTED
DDM C522
  • Does the keypad illumination turn off?
No GO to L15 . L15 CHECK KEYLESS ENTRY KEYPAD FOR SHORT TO GROUND
Yes GO to L16 .
No INSTALL a new keyless entry keypad switch. For additional information, REFER to Keypad-Keyless Entry . TEST the system for normal operation. L16 CHECK CIRCUIT 66 (LB) FOR SHORT TO GROUND Measure resistance between DDM C522-4, circuit 66 (LB), and ground.
  • Is resistance greater than 10,000 ohms?
Yes System OK. CLARIFY the concern with the customer.
No REPAIR circuit 66 (LB). TEST the system for normal operation.
Nov 03, 2017 | Lincoln Town Car Cars & Trucks
Keypad locked of Google Android phone
Open and remove the battery. Replace battery and close. Hit the Power button
Mar 09, 2009 | Google Android
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
48 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
