Question about Seiko DPU 414 Matrix Printer
How to install dpu printer to jrc nc 333 navtex reciever
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
I have a DPU-414 Thermal printer that just won't get dark enough. I have already changed the switch settings to its highest density 121%....
Access and clean the area where the paper runs over the heating/printing element. This area picks up foreign substances and bakes them so that the paper no longer makes proper contact with the print head. Use something like an alcohol based solvent to remove any build-up in this area.
May 03, 2011 | Seiko DPU 414 Matrix Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
I have windows vista and when i go to install the printer i cant find this model dpu 414 help?
This printer isn't supported in Vista. All you can do is to install a Virtual machine, XP on it and the printer in that XP.
Aug 30, 2010 | Seiko DPU 414 Matrix Printer
Need drivers for a Seiko DPU 5400 or 5442Themal printer
This web site will help you find your driver automaticly
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
Feb 23, 2010 | Seiko DPU 5442-1B Label Printer
Calibrate a DPU3445
go to this website:
http://sii-thermalprinters.com/thermal-printers/mobile-printers-DPU-3445.aspx
it is seiko's official website, but you will need to register to be able to download the manuals.
good luck.
Dec 02, 2009 | Seiko DPU 3445 Thermal Printer
I am having problems with my dpu 3445. the print
Usually you just need to wipe the rail it travels on with alcohol, and oil lightly so the carriage moves freely again...
Oct 13, 2009 | Seiko DPU 3445 Thermal Printer
Jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
pcg1@orange.fr
Jun 13, 2008 | GPS
Navyex
No.
This unit was GPS with WAAS only.
No Navtex capability whatsoever.
Sep 27, 2007 | Raymarine Raynav 300 GPS Receiver
Seiko DPU 414 Matrix Printer Logo
54 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
