Question about New Home Sewing Machines
My new home combi dx 520 will not switch over to the overlock stitching side of the machine? Do not know where to take to get it fixed
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
clyde2j2
  • 137 Answers
SOURCE: Replacement parts for New Home 222 combi (1983)
Try: www.sewingmachinepartsonline.com
Posted on Mar 02, 2009
micromaster
  • 3614 Answers
SOURCE: Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Posted on Jun 01, 2009
Zenqi
  • 208 Answers
SOURCE: sewing machine stopped making the stich
Unthread the needles, rethread the loopers properly, then rethread the needles. Make sure that all four threads are pulled securely into the tensions and retry.
The loopers must always be threaded before the needles or it will not chain.
Posted on Jul 19, 2009
  • 1116 Answers
SOURCE: Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
Posted on May 09, 2010
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Overlocker looping(forming chain stitch) not stitching on fabric
try new needles
make sure tension is correct
could possibly be in need of some adjustment
Mar 29, 2014 | Sewing Machines
My machine is doing stretch stitch on straight stitch position
sounds like a gear has worn or gotten damaged, a trip to the repair
shop would be a good idea
Aug 19, 2012 | New Home Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
I find my janome overlock machine is very slow ,i would like to know how to increase its speed
There is no speed seperate control on overlockers other than the foot control but most sew at 1500 stitches per minute, very fast compared to sewing machines.
What is your stitch length set to as this could be the problem. For normal four thread stretch seam you would want the length set to beween 2 and 3 so double check this - the length knob is usually a knob on the right side near the flywheel.
Hopefully, the above solves the problem for you but if not, please message again.
Aug 28, 2011 | Janome 1600P-DB Mechanical Sewing Machine
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
I am interested in buying a Janome 525 but want to know if it has a built in overlocker
A sewing machine and an overlocker are two completly different things, but a sewing machine is usually able to do a cover stitch. An overlocker will cut the fabric at the same time, a sewing machine cannot do this.
Jan 25, 2011 | Janome Sewist 525S Mechanical Sewing...
May 09, 2010 | Baby Lock Evolve
Whats the differance between a overlocker and a sewing machine? I am new to sewing and want to know with to purchases, iv no idea where to start or what to buy?
A overlock machine helps you clean finish the seams. You can do many things with a overlock It can cut your sewing time down. The sewing machine is good for many thing too,Mostly the construction of the garment. I have three machines. A indstrialstraight stitch, a home machine and a overlock.Al for different tasks.
Aug 05, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
48 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
