Question about Amana ARS2464B Side by Side Refrigerator
Amana side by side not cooling well, will not freeze water.
I have an Amana side by side that does not freeze and cools poorly. It is an SXD22S2l MF# p1190416wl. I have cleaned the condenser under the unit very thoroughly. The unit runs, the compressor runs, the condones outlet from the compressor gets hot. The fans run. The evaporator coils only get cold at the very top. The first few inches are painfully cold, by the first turn it is cold, none of the front coils feel cool at all. This is after 30 minutes of running with the cover off so no air is going over them. I would think they would be freezing since the air is not there to warm them up. The defrost heater is not on, in fact I undid the clips so that even if it does come on it won't warm the coils, and it is not sitting on anything that can melt or burn, so don't worry. Before digging in this far I replaced the adaptive defrost controller but I really don't thing that is the issue. Even if I tape the light switches up so it doesn't know the door is opening (all three of the door switches) it still does the same thing. I suspect low Freon or something with the evaporator, but that is beyond my tool set to test. Have I missed something? Should I call a repair man or get a new/used unit. Thank you.
  • 410 Answers
If you are only seeing frost on the top portion of the evap coil then you then it sounds as if the unit has sealed system problem (low freon or bad compressor). if the unit is less than 5 years old and made prior to nov '06 it should have a sealed system warranty. if the unit is out of warranty you may want to start looking at new refrigs. good luck peyton
Posted on Jan 24, 2009
The top portion of both the freezer and fridge are warm but bottom half are freezing.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Amana ARSE66MB Side by Side Refrigerator
Fridge freezer keeps freezing up
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 15, 2010 | Amana ACD2234HRS Side by Side Refrigerator
Refigerator is freezing the food at all settings
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | Amana ASD2626HE Side by Side Refrigerator
Amana side by side fridge model sxd22s2l freezer/fridge not cold
they can get up to 305 degree F they can make brown spots on floor... yes they get very hot(is normal)
Aug 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer problem
Have you checked the Heater element for the defrost to see if it's good? It sounds like the coils inside your freezer are freezing over into a solid block of ice which in turn will cause it to stop cooling.....efficiently. When you leave the unit unplugged, it gives the unit a chance to thaw and it work properly until the coils freeze over again. If heater is not the problem then Defrost Thermostat probably is. Both located in back of Freezer.
Nov 23, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARS2464B Side by Side Refrigerator Logo
224 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
