Question about Panasonic NV-GS17 Mini DV Digital Camcorder
Tape holder jammed
The tape holder retracted into the body of the camera without it first being pushed down. As such, the tape holder prevents closure of the camcorder. How do I get the tape holder to come out?
  • 73 Answers
Remove the battery and use the charger - press eject button repeatedly , while plugging charger in ( if mechanism is out of alignment , will start to eject but reload immediately ) ;
Posted on Jul 31, 2007
SOURCE:
The cassette door to this camera will not retract when I try to close it. as you probably know you close the door partially, the casstte holder retracts and then you can finish closing the door. When i...
Hi.
My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing can be repaired fairly inexpensively but will require disassembly by a qualified technician. The camera will need to be disassembled to remove the tape mechanism and then the tape mechanism will need to be disassembled to repair. If I can be of any help please call or email me and I'll get the camera working for you.
Dec 27, 2011 | Sony Handycam DCR-IP5 Micro MV Digital...
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Hi. I open the top to insert a tape, and after the tape holder opens, the camera bleeps five or six times. If I insert at tape, and close the holder, it starts to load, then bleeps a few times and...
This sounds like a run motor issue and will require major disassembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 25, 2011 | Canon HV20 HDV Digital Camcorder
Sony CCD TR31 - tape holder will not lower into camcorder
Does the tape have blocking tabs that prevent recording? May be telling you that you can't use that particular tape.
If not take it in for professional repair. I think Sony is in Mississauga.
Andrew in Mississauga :>)
May 16, 2017 | Panasonic PV-GS2 Mini DV Digital Camcorder
Canon zr 300 won't take tape inside
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Dec 01, 2008 | Canon ZR300 Mini DV Digital Camcorder
I found a loose part in the VCR bay I'd like to reinstall. Part #T5B
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
Oct 12, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Tape Won't Load
try this quick fix. check and see if the video head is bound. I have seen alot of these stick. put your figure on the top edge of the head only and see if is free spinning on not. sometimes you can more it one way or the other and free it up. this problem could also just require a tape path cleaning. anything sticky on the tape path or head will cause this.
May 03, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Eject stuck open
Yeah i have a PV-GS70 and the same thing happened to me. The casing is still open as we speak. Im taking it to a camera shop tomorrow
Sep 22, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic NV-GS17 Mini DV Digital Camcorder Logo
197 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
