Question about Sanyo DS25390 TV
Connecting VCR/DVD combo
My 80 year old father has this model TV,(DS25390) and I bought him a Magnavox DVD/VCR combo and am having trouble hooking it up. I bought a modulator, hooking up the TV to the TV hookup in the back of the modulator, the cable cord (he has no cable box, just a cable that comes through the wall)to the antenna on the back of the modulator, the red/yellow/white cables hooked from the VCR/DVD to the back of the modulator (under VCR/DVD column) The player is running, but have no picture from the movie or no audio from the movie. Have the TV on channel 3, modulator is set on channel 3. What am I doing wrong. HELP
  • 147 Answers
Put the Tv on Channel 3
Posted on Jul 19, 2007
SOURCE:
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
Can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
Sep 24, 2007 | Televison & Video
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
347 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
