Question about GE JE1460 Microwave Oven
Why does model # wes1450ds1bb not cut off or heat
Has been unpluged and when you plug it back in it runs with out doing anything but does not heat.
2 Suggested Answers
  • 547 Answers
SOURCE: I have a ge microwave wes1450ds1bb it will run but will not heat. Can i replace a fuse to solve this problem. Thanks, Diane
There are multiple possible causes for this problem, but a fuse isn't one of them. Possibilities include a bad magnetron, rectifier failure, open or bad power transformer, or something has failed in the control system. Many times you can visually inspect the rectifier to see if it show signs of over heating.
Posted on Mar 06, 2015
Mar 06, 2015 | GE Microwave Ovens
Microve wILL NOT DO ANY THING COMPLETELY WENT OUT .
  1. Every microwave I've seen has a fuse in the 110 VAC line. Remove the cover or access panels and look for a ceramic or glass tube fuse with metal end caps. Replace with the same value, which is often 20 Amps.
Mar 02, 2015 | Oster OGB61101 1.1 Cubic Foot 1000-Watt...
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
What do i do after my microwave overheated and shut off?
they have a built in overload thermo cut out when it is on for a long time it will cut out cool down and should be ok to use again
May 28, 2012 | Emerson Microwave Ovens
My microwave wont heat up but runs normal
The make & model number would be helpful. There are alot of veriables that might cause this to occur. How long was the MW in use (the unit might have been to hot and the safety engaged) keeping the fan on to cool it down. There could be an issue with with one of the door interlock switches. Depending on the engineering, the control board could have had a hickup via a over current & shut down to protect itself. During the cut out was the cavity light on when the door was open. was the display blank. If you unplugged the unit waited a minute & then plugged it back in, did it operate again. It is not a good idea to open the control panel up, if your do not understand how to do basic electrical troubleshooting.
Mar 27, 2012 | Frigidaire Microwave Ovens
Constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
May 17, 2009 | GE Microwave Ovens
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Feb 01, 2009 | Microwave Ovens
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
GE JE1460 Microwave Oven Logo
124 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
