Open a port for u torrent in a thomson st 780 wl
Just changed provider today from cable to adsl and now my port for u torrent isn't open anymore , on port forward there is no configuration
of my modem thomson st 780 wl
  • 83 Answers
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Hello, Any driver for Thomson ST 330 USB ADSL modem for windows 7 64 bit?
It's kind of a tough one to search for on Google isn't it? Since Thomson is a very common name, you can't very well just search for "Thomson" without pulling up ever Tom Thomas and Tommy in America. However, your Drivers are here:
http://www.speedtouch.net.nz/st330.htm
Feb 24, 2011 | Thomson SpeedTouch 330 ADSL Modem
Modem and Router connected but cannot access internet.
ADSL Modem's LAN -> connect to your Router's Brodband port through ethernet cable.
or
connected through bridging or POP
Apr 02, 2010 | Computers & Internet
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Shareaza bad downloading not more than 30 kb s my system is window  vista,  modem is thomson st 780 wl from kpn,  port 6346 , what now?how must i configurate the fire wall and modem speed...
your downloading speed depends on your connection primarily and not your modem, check what connection you have. the downloading speed is much less than the connection speed.
conncection---------downloading speed(Avg) 256kbps 30kbps 512kbps 60kbps 1mbps ~110kbps etc.
You must be having a 256 Kbps connection that is why your downloading speed is very slow.
May 06, 2009 | Computers & Internet
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
Can not get my adsl modem to connect through ASUS wireless router
it could be the modem and the router has the same ip address. the asus router has an ip of 192.168.1.1, check if the dynalink modem has an ip of 192.168.1.x. if so, change the router's ip to 192.168.x.x (e.g. 192.168.2.1) then see if you'll be able to connect to the internet while the modem is connected to the wan port of the router
Apr 02, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Speedtouch username and password
i need user name and passowrd for modem speed touch
Nov 12, 2007 | Computers & Internet
Slow downloading
Hi, DL managers usually split the file into many pieces, but the DL manager tries to grab many pieces at once and often there haven't been enough Ports opened to allow for this so check that also. Sometimesya ISP don't like torrents anyway and restrict that those ports into and out of ya conection..
Aug 03, 2007 | ASUS WL-700gE Router
Televison & Video Logo
1,204 people viewed this question
Top Televison & Video Experts
