Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener unresponsive.
I took apart my older Chamberlain Liftmaster Security Plus to replace Nylon gears that had stripped in the Wisconsin winter. I reassembled & left out the sensor cap so the motor would only go a couple inches. I was told about the infra red sensor so I disassembled & replaced the cap. I re-hung but now neither remote (wall or car) gets a peep out of the unit. I've tried cutting the power to reset & pushed the red button on the back. I've got the black striped wire from either side going to the right hand terminal the white from either side plus the white from the red wire going to the left terminal & the remaining red wire going to the far left. Power supply is good/light comes on. Any reset steps I've missed?
  • 118 Answers
You need to reset the limit settings. There are three white screws on the bottom of the opener with the cover off. You will need to take the bottom off the gear and sprocket assembly. Turn the middle screw to where the wings are most of the way up and move the trolley to the up position. Put the bottom of the gear and sprocket back on and adjust the two other screws ti make door open and close completely
Posted on Jan 26, 2009
My garage door only opens up about 2" and stops.
Check for a broken door spring and remove the cover from the motor unit and check for a stripped drive gear. The gear is white nylon and it will be obvious if it is bad.
Feb 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster will open three inches and then go back down? Any suggestios
Check your door springs and also remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: garage door opener only runs for a foot or two and...
Check to make sure you don't have a broken door spring and also remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a old Liftmaster Garage Door Opener. This morning when I pushed the button the motor went on but the chain didn't move to open the door. What's the story?
If you remove the cover I'm sure you will find the drive gear is stripped. It is a white nylon gear just in front of the motor. It is available at any good door opener service company and comes with instructions.
Jan 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsmen garage door is not opening. It started
Your drive gear must be stripped. Remove the cover and you will most likely find lots of what looks like white sawdust and a stripped gear. It is white nylon and is just in front of the motor. The part number is 41A2817 if you want to replace it and it comes with instructions. Available at any good door opener service company.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nylon gear replacement for automatic garage door
If you buy the gear kit it comes with a set of instructions. The part number is 41A2817.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door barely opens/ opens with physical lifting assistance
It sounds like you have a broken door spring or the drive gear in the opener is stripped. You will have to take the cover off the opener and you will find the white nylon gear just in front of the motor.
Sep 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
The nylon drive gear on Craftsman Garage Door keep stripping
The most common reason for this is a door that is too heavy. Release the door from the opener and lift it by hand. If it is heavy to you it is heavy for the opener. Be sure after replacing the gear to lubricate it heavily with the lubricant supplied with the gear. You can't apply too much.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
178 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
