Question about Omron HEM 650 Wrist Blood Pressure Monitor
Does not inflate, even after NEW batteries and reset of data.
I went through the setting of date and time successfully. Then tried to find my blood pressure data. The OMRON HEM-650 unit lights up the full screen on start. However, the screen is all out except for irregular heartbeat signal, and I can hear the beep - beep, which continues but the unit does not inflate. Nothing else happens, even after a 2 5 minute wait period. I finally stop the unit.
Can you please tell me what I might do to get the proper response from the unit?
  • 1 more comment
  • rrankl2006 Jan 24, 2009
    I repeated the entire procedure, which I initially reported.
    The results are exactly the same.
    Is there something further I should be doing?
  • awojyn Feb 23, 2009
    I have the same problem where everything is set correctly, but I get an E with a 0 and the little heart, but no reading.
    This is stupid, if you can throw off the cuff setting, it should be able to be reset, don't you think?
  • Jmd_pepe Mar 24, 2009
    Hi!. I am Dennis from Mexico.
    I have the blood pressure monitor HEM-608, and do not inflate, only appears a small heart and when I push the start button, appear E letter and the down arrow.
I dont have my paper work to my cuff,how can i find another so i can fix my problem. s.cantu
Posted on Jan 22, 2010
  • 40 Answers
Its seems like when you were doing the settings for your monitor you didnt take it back to the start position so you need to read the instructions from your papers and go back to the begining and restart all over with the settings, it seems like you have knocked off the settings somewhere which also controls the inflation of the cuff and the cuff will not inflate while the settings are not set right so restart from your instructions and see if this will help you. good luck!
Posted on Jan 24, 2009
Cuff doesn't inflate lifesource ua767 bp monitor. How do I reset or fix this? Have brand new batteries.
Inflating a Blood Pressure Cuff - YouTube
? 1:01
Sep 30, 2008 - Uploaded by expertvillage When you take a blood pressure reading it is important to inflatethe blood pressure cuff until you no longer ...
Sep 24, 2015 | Lifesource Health & Beauty
What's causing air inflation problem?
then contact the company for a replacement
Jun 30, 2015 | Braun Bp-5900 Exactfit Plus Bp Monitor
Why does my blood pressure not inflate even after new batteries
It sounds like you might have a leak some where. Check the hoses very carefully for any damage. It would be helpful to submerge the hose in some water to find an air leak, but be careful not to get the unit wet. You will want to start it and check for air bubbles in the water. Good luck.
Apr 22, 2015 | Health & Beauty
Why does my blood pressure monitor not inflate fully even after new batteries
Maybe your losing air pressure in the line. See if it's cracked somewhere, also the bulb may have some cracks in it.
Apr 22, 2015 | Panasonic EW3109W Upper Arm Blood Pressure...
Hi, on my JB5538 Wristech, even with brand new batteries, the unit never seems to inflate ! It developed this problem about 3 months ago out of the blue. Keep getting Err message. How do I fix it ? Th
either the compressor unit seals are damaged or you have a hole in the inflatable section either way it is not an easy fix and as they have come down in price dramatically over the past year i would suggest buying a new model & chucking this one away
Nov 12, 2014 | Health & Beauty
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your will not lose the memory. The unit will store up to 90 measurements in non-volatile it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
Repeat steps 2 and 3 to set the
The month is set and the day
The day is set and the hour digits
The hour is set and the minutes
The minutes settings is set.
button (
) to turn the monitor
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Jan 31, 2018 | Omron HEM-780N2 Automatic Blood Pressure...
Won't take blood pressure
I changed the batteries, Duh. I changed them once but apparently I has a dud. I opened a new pack of batteries and that took care of it.
Mar 21, 2009 | Mabis SmartRead Blood Pressure Monitor...
I have a e system desktop the clock keeps running late
Computers have an internal battery on the motherboard that helpd the board retain certain data when the computer is off. If the battery is low or dead it will cause this problem. The easiest way to replace the battery is to open the side of the computer when it is off and remove the battery from the battery holder on the motherboard. The battery looks just like a watch battery. Replace it with the same kind of battery (available at most drug stores) once you have replaced it turn on your computer and reset your clock.
Dec 29, 2008 | E-Machines eMachines Desktop PC
Omron HEM 650 Wrist Blood Pressure Monitor Logo
1,359 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
