Question about D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter
Can't connect To internet w/ Wireless
I can't connect to the Internet -- the icon on the trey says no signal -- we have wireless connectivity in our house through Comcast. My wife's computer connects just fine. I have an older Dell system and use a D-Link AirPlus G DWL-G630 wireless card that fits in a PCMCIA card slot on the side of ym laptop. Could the card be failing? It has worked fine for several years. I haven't done anything to my laptop or installed anything new that might change settings. Do I need to go out and buy a new card? Is there anything else I can do to try and troubleshoot this problem on my own?
  • davehammond Jan 24, 2009
    when you say uninstall, do you mean take the card out? I did that and then put it back in -- is that what you mean?
    If drivers have to be installed or downloaded how do i do that when I can't connec to the Internet?
How can i install my airplus g dwl-g630 wireless notebook adapter without cd
Posted on Mar 10, 2009
  • 871 Answers
Try uninstalling it and re-installing it. the problem may be with its drivers.
Posted on Jan 24, 2009
  • 1 more comment
  • earl norman llanera
    earl norman llanera Jan 24, 2009
    well, usually when you put the card in, the laptop automatically detects it right and installs it. but with your case, you may want to check the wifi card in the device manager. if its enabled and working properly. pls check with the wificards manufacturers site because they may have updates for your card. it seems that this may be like about compatibility issue with the old dell laptop your using.
    you can do that using computer there. all you need to do is check whether there is a driver update for your D-link airplus to be able to work with your dell laptop in terms of drivers.
    as for the OS youre using, if its WinXP, try using windows Zero Config. As for Vista, it is automatic.
    if there is such new drivers for your dlink airplus, you need to download it and copy that to a flashdrive and install it on the dell laptop.
We are paying for netflix. How do we get it on our television? Our television is connected to comcast and we have wifi?
But is your TV a "Smart TV"? That means does the TV connect to the internet. Just because you have Comcast connected to your TV doesn't mean it is getting an internet signal. The black coax to the TV only carries a TV signal.
To get internet service to your TV first you have to determine if it is capable. If it does have a wireless receiver in it, you will have to configure it to attach to your wireless base station. If it doesn't have a wireless adapter you will have to connect a network cable from the base station into the TV and then configure it to work with your network. Once you have that internet signal working on your TV you will be able to use Netflix on your TV.
Mar 01, 2015 | Netflix
Internet status light on netgear wireless n300 blinking. internet service on and off. 2 macs in house.
You can do a reset on the router to make a factory settings.On the back of the router you can look for a small hole usually with the word reset.Press it for 20 secs with the router on but disconnected from the Ethernet cable.Start up your PC and surf to the router Web UI (192.168.***) and make your settings.
May 26, 2012 | NetGear WNR2000 Wireless Router
Comcast Cable Down All Day Every Day
Here's some things to check:
If there are signal splitters on your cable for TV, computer, more than one tv, the signal is getting divided ...every splitter will weaken the signal.
Check for unneeded splitters, also there are splitters that have a wider frequency capability.
Consider upgrading to 2hgz splitters if needed.
Also I think that the more homes that are on the cable tend to make the signal weaker...I don't comcast would fess up to this, but I'm pretty sure it's true.
Make sure all your cable connections are snug and you may want to double check for corrosion etc. on each connection.
I resorted to a signal amplifier on my home. We've got comcast for cable tv and internet, with multiple tv's and multiple computers.
The amplifier (motorola) boosted the signal for everything and we've got way less dropped, frozen pix, black screens and the internet is back up to speed.
Comcast even came out and put a signal strength meter on the in-line to the house and stated it's within their limits... Glad I put the amp on the line..
Give it a try.
K
Sep 01, 2009 | Pioneer VSX-406 Receiver
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
I just posted a question regarding a D-Link AirPlus G DWL-G630 wireless card I have plugged into the pcmcia slot in an older dell laptop. I have wireless service through Comcast. I can't connect to the...
so your saying that your using the pcmcia card on an older dell laptop. everything else works but that...
have you tried uninstalling the drivers and re-installing again? or maybe you need some updates on your D-Link wifi card.
older dell laptops usually have driver issues so be patient with that.
Jan 24, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
My ps3 continues to lose internet conection to my wireless router. The router I am using is a belkin G plus mimo. it always happens about 5-10 minutes into a game (college football 09). My new internet...
there are many possible reasons and solutions for this
-sometimes the weather can block the signal to a router or PS3
-the closer the router is to your PS3 the better the signal
-try not to have a wall interfering with the signal to the ps3
-a computer in your house may have a signal that is interfering with the signal to your ps3
-maybe comcast just sucks?
-try using a wired connection
Jul 26, 2008 | Video Game Consoles & Games
Wireless G and Comcast cable internet
Im not sure about the monopoly thing?
But it must the settings that is causing a problem.
If I understand you concern correctly your computer is connecting to the router wirelessly, is that right?
and can you get online if the computer is wired directly to the router?
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Lost internet
The usb stick is replacing the job of the card in the pc so it could be faulty, but first reinstall the latest driver for it and give it another try - what version of windowns/linux to do run? What make is the card - (look in Device Manager)? Then I can help further if needed.
Thanks
Jul 05, 2008 | HP Pavilion dv6000z Notebook
Internet will not connect through router.
Hello Orionj2
We can provide you with the best Comcast internet tech support, so if your Comcast internet is not working fine, then you just have to get in touch with support. Call us today and get internet related issues fixed.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
Sep 20, 2007 | Belkin (F5D5231-4) Router
After I installed a new printer I cannot get online.
Do you have a firewall installed? If so, disable it and see if that helps. Try a system restore, Start, programs, accessories, system tools, system restore. It will give you a list of dates to restore to. Put the latest date that you knew that you had a working connection.
Sep 03, 2007 | HP Pavilion zd7020US Notebook
D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter Logo
289 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
